Help with 5.4 3 valve
Old 08-18-2013, 02:07 PM
lowblack150's Avatar
lowblack150
lowblack150 is offline
I am rebuilding a 2005 5.4 3 valve motor. I have bored the block .30 over had crank turned. I am installing the Comp Cams ***** thumper mt273ll with cam phaser limiter kit and springs for the heads. I have the heads reworked as well. Can someone tell me where to get a aftermarket intake,headers,and where I could send the computer to have it turned for the mods. I was also wanting to know what is the stock size of the throttle body as I was thinking about going bigger with it. Any help would be great.
Old 08-21-2013, 01:31 PM
jeremy1's Avatar
jeremy1
jeremy1 is offline
I have a K&N cold air intake on my stock truck and it works well. Gives the engine some throat sound. There are tons of exhaust choices out there. The only thing I know about headers is they are a pain to install on an f150.
Old 08-21-2013, 08:44 PM
lowblack150
Thanks for the reply. I have the K&N cold air for it. I have the motor out the truck now so the headers should not be a big deal(I HOPE) I am waiting on another set of rings o come in now. I got shorted the #2 ring. Hopefully it will be here tomorrow.
Old 08-22-2013, 02:40 PM
tooldad's Avatar
tooldad
tooldad is offline
Did you pull the engine out the front or raise the cab? Just curious, have heard of folks doing either.
Old 08-22-2013, 09:33 PM
lowblack150
I pulled engine and trans out the front. Putting it back in motor first and then trans. It was a pain pulling them out at the same time.
forddieseltech08
Modular V8 (4.6L, 5.4L)
08-25-2013 10:39 AM
79mustang351w
06-23-2010 04:14 AM
RaptOut
03-03-2010 06:38 PM
mtgloyd20
1999 to 2016 Super Duty
04-03-2009 07:21 AM
COACHBRITT
01-12-2006 08:09 PM
Quick Reply: Help with 5.4 3 valve
