99 f150 trouble codes 171,174, and 455
Well tell ya what!
You didn't fix the first 171 code because it's back with it's partner 174.
These codes are related due to the same cause, an intake air leak affecting both banks.
The 455 is the fuel tank system diagnostics----- a gross leak detected.
The cap , fill pipe, stuck open solenoid or some hole, and not normally related to 171/174.
Good luck.
Good luck.
