Runs better with SPOUT connector removed??
#32
I totally agree that the Kjet is stupid. I worked for a Volkswagen Dealer in the late '70s so we worked on a lot of them in Rabbits. The Volvo version worked a little better though.
They tell me the Volvo pulleys came apart due to people using a 3 jaw puller to remove the pulley for timing belt changes. It sounds plausible to me.
It doesn't look like I'll get to work on the truck until weekend due to work related pressures. I'll keep you guys informed as to what I find.
Thanks for all the help,
Tony
Tony
How & where did kjet get into this topic????
I think Tony that the computer option is worth looking into. I would take yours out & open it up & see if you see any corrosion or dull solder joints. See what it looks like inside, you might see a problem right off maybe not. Only if you can get a replacement fairly cheap that will work. Maybe try that. Heck I would think a wrecking yard would trade you I would think the Mustang would be worth more & be more sell-able, maybe not.
Craig
Craig
[QUOTE=mejonz;13443562]Yes I Believe mid 70's perhaps earlier. There were a few variants of it too Mercedes used it all the way up until they no longer made the w126. 92? I think.
#33
If you have a junkyard local to you go there and look for a truck with similar options to yours. IE. 5.0, manual or auto 4x4 or 2wd whatever your truck is.
The replacement PCM I'm using in my truck is from a '90 and my truck is a '93 but it works great cuz the truck it came out of was a 4.9l manual trans just like my truck.
I really miss the "you pick" yards... we found the coolest stuff every time we went there.
I'll run through all the test we talked about and if it looks like the EEC I'll take mine apart to see if it's something simple. If not then I'll start looking on Craig's list and our local "buy-sale-trade" site. Someone, somewhere has one they took off when they did an upgrade of engine change... I just need to find them.
Tony
#34
I love the red block Volvo engines. I wish everything was built as well and as simple. If it weren't for the crappy crumbling wiring harness I think they would be the most reliable cars of all times. They fixed the wiring in 1989 and I drove a 240 wagon for 400,000 miles and only sold it because my wife died and I didn't want to see the car anymore (it was hers)..... but I have seriously digressed!
Time to get off my butt and work on the truck before the rain gets here.
Later,
Tony
#36
[QUOTE=Krisverde;13444183]I just cant believe how long Mercedes used it for. Dunno why people are using a jaw puller on the redblock pulleys i've always been able to remove it by hand MAYBE a little tappy. Usually timing belt changes take me about an hour on those cars. Redblock is so simple.
Beat me to it! Forgot to mention that it was for a maf 5.0
PO was talking about bosch CIS earlier aka kjet.
Thanks, tells you how stupid I am when it comes to imports. I got out when computers came in to the automotive field.
Craig
Craig
#38
#39
Well, I looked at a lot of things today and I'm down to thinking it's the EEC. I checked for timing chain wear using the rotor... I had about 10 degrees of movement so the most it could effect timing would be 5 degrees up or down so we can rule that out.
I reconnected the timing light and tested by revving the engine and watching the timing. It never varied off of ten degrees. Below is a picture of the timing while running. The wide white line is TDC and the short marks are 10, 20, 30 degrees before. As you can see its right on 10 degrees.
https://www.dropbox.com/s/c9cvintcz0...F150Timing.JPG
I pulled the KOEO and KOER codes and there were none (except self induced codes). I did not pull the battery cable again because i didn't want to erase the codes. I did go drive it for almost and hour with the SPOUT off before I checked the codes so I was shocked when I didn't have a code set for the lack of SPOUT signal.
I didn't have time to remove the EEC and look at it but I plan on doing that tomorrow.
I think I getting closer........
Tony
Tony
#40
Just so you know, I'm not trying to be a smart a$$ by asking this, I'm just making sure..
#42
#43
Is that clearer? I am a do-er not a teacher, sometimes I have trouble explaining things so others can understand.
All in all I think you are on the right track, it sounds like the computer needs defragmenting!!!!!
#44
#45
