inside door trim what you think?
Buyer beware. This is an item that sold for $100.00 on ebay, Here's the description.
66 ford truck custom cab interior door trim set
should fit 61 - 66 f100 - f250 custom cabs
Note : I have two bottom right as I am missing the bottom left
you can modify the right to work by cutting the end "cap" off
so it will slide on the corner piece.
Would you buy this set for the price? If you did not have the correct piece?
$100.00 is a roaring bargain!
C4TZ-8120962-A Right & C4TZ-8120963-A Left .. Lower Door Trim Panel Mouldings.
C4TZ-8120986-A Right & C4TZ-8120987-A Left .. Rear Door Trim Panel Mouldings.
C4TZ-8120996-A Right & C4TZ-8120997-A Left .. Upper Door Trim Panel Mouldings.
Original applications: 1964/66 F100/250 Custom Cabs & 1965/66 F100/250 Rangers.
But, they'll fit all: 1961/66 F100/1100 - 1963/69 N/NT/T500/1100 - 1967/69 F800/1000 cuz the doors are basically the same.
1965GTFB
15
08-30-2018 04:01 PM
clinkfield
02-12-2015 01:29 AM
Vashon Islander
08-25-2014 08:40 PM
Shadowrider123
19
01-15-2014 09:31 AM
