My turn signals have never automatically turned off since I bought it so today I went to replace the switch. I bought the repair kit and installed it. I went to test it and it worked except for the right turn signal indicator light didn't flash. I pulled it off and then tried the emergency flashers. There was a small puff of smoke from the steering column I think but no noise. Now the turn signals don't work but the flashers still do. How can I test if the whole switch is dead or if the repair kit is just installed wrong.
Update: all of the pads on the switch are connected to ground (with my multimeter on the connectivity signal setting all the pads are connected and all of then are connected to ground) is this normal?
I attempted to replace the top of my switch with no good results. I replaced the entire switch. A note on this is Ford used the same switch with exception of harness length in many different vehicles. My column is a tilt unit from a '78/'79. I ended up using a turn signal switch from a T Bird. I think it was a '77.
My column is a tilt unit from a '78/'79. I ended up using a turn signal switch from a T Bird, I think it was a '77.
C9TZ-13341-C .. T/S Switch:
1965/66 F100/250 2WD - 1966 F100 4WD - 1967/68 F100/350 - 1969 F100/350 before serial number G30,001.
----------------------------------------------------------------------------------------------------------------------------- D0TZ-13341-B .. T/S Switch:
1969 F100/350 from serial number G30,001 - 1970/72 F100/350.
-------------------------------------------------------------------------- D6OZ-13341-A .. T/S Switch-Use with Tilt Steering Column:
1974/76 Torino/Montego/Ranchero - 1974/79 Cougar - 1977/79 Thunderbird/Continental Mark V/LTD II (not an LTD!)/Ranchero.
------------------------------------------------------------------------------------------------------------------------------------------------ D6OZ-13341-B .. T/S Switch-Use without Tilt Steering Column:
1973/76 Torino/Montego/Ranchero - 1974/79 Cougar - 1975/80 Pinto/Bobcat - 1977/79 Thunderbird/LTD II (not an LTD!)/Ranchero.
------------------------------------------------------------------------------------------------------------------------------------------------------ D8TZ-13341-A .. T/S Switch-Use with Tilt Steering Column:
Replaced the turn signal switch assembly, and I still don't have the auto cancel. Im thinking I'm missing a part on the wheel that hits the canceling cam on the switch. But I have nothing to compare to.
Been so long, but I'm guessing there should be a pin hanging down on the back side of the wheel to catch the cancel tabs. I have a wheel in the basement, need to look at it to see.
EDIT: PIC IS FOR 2WD & 1967/72 F350
13318 = "Turn Indicator Turn Off Cam" / 13341 is the switch / 13A823 = "Horn Switch Brush Plate"
