Is My Intake Manifold Cracked?
But if your truck is as old as mine, chances are those boots are soggier and looser than you'd believe. I replaced mine with some boots and clamps from Clay when I installed my 38R last Christmas.
The intake manifold boots were so loose and soggy (wouldn't stay in place if I tried to tighten them), it was no wonder they were covered in oil, my mileage sucked, and boost seemed low. While the 38R played a role, the boots and clamps from Clay made sure the intake manifold would stay in place and not leak precious boost.
Where would that be located sir? It also looks like I have a new spider coming thanks to my really cool wife. Even though my original is not cracked, she ordered me a new AFE Bladerunner for some bling! I also have some RiffRaff boots on the way! Anything I should look for while doing the swap?
Why does it look like your MAP hose isn't plugged in at the first pic?
I would have guessed it was because you had some redneck engineered excuse for a clamp and you let some idiot beat on your CAC tubes with a hammer to try and make them round again.
EBPV can be seen from the passenger side if you look under (or hold a camera under) the spider. Oily boots are normal though, so don't worry too much about that.
Here's what it looks like dirty
And if you clean it up a little, you can actually see there is a rod coming out of that thing
Wonder who that guy was? LOL!
It held perfectly till I upgraded to some boots and clamps from Clay.
It looks like it may be leaking a little bit. I had the pedestal o-rings changed last year, so it may possibly be from then? It also looks like they put silicone on the turbo flange where the spider clamps to it. Is the o-ring by itself not good enough? Any thoughts? I am installing a new spider and boots, so now would definitely be the time to fix what I need to. Have I ever mentioned that I live this forum!! I feel like family!
Word to the wise on the AFE Bladerunner, you'll have to trim the boots for it to properly fit and tighten. I have the CFM+ intake manifold and it doesn't quite fit the way it should and needs some trimming around the top of the boots for a good fit.
You will, however, feel the boost you've been missing between the boots and the Bladerunner you have.
Keep us posted on the details!
