1999 F-250LD rear door won't open
It was working fine then I drove on a 2 hour highway trip and now it will not open. This is the Xtra cab where you open the front door and then the rear from the inside. The door ajar switch is out. Any help would be appreciated. I suspect one of the latches is stuck. There is one on the top and one on the bottom of the door.
Thanks!!!!
Thanks!!!!
ok
Did some research and there are some posts where the cable assembly degrades and leaves the door stuck. Now the trick is getting the door open. I saw some posts on this but none that really helped on how to get into the panels. I don't see any screws. Help if you can 1999 F250 LD Supercab
if your tuck is anything like my f150 then check this out, It is what "walked me through" fixing mine when it went, I don't remember what the part cost though. I had to do it a couple times because the temp fix didn't last very long at all, Once I got the new cable, No issues since.
http://www.f150online.com/forums/199...wont-open.html
Polkster
11-16-2013 08:49 PM
GSDgirl
09-02-2007 09:07 AM
