2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2009 Navigator - Factory Keypad Code
Old 08-01-2013, 06:13 PM
jurban91's Avatar
jurban91
jurban91 is offline
Hi everyone,
I am trying to find the factory keypad code for my 2009 Navigator L.
Been looking around the forum for a few days. I have tried to look into the fuse-box located under the glove compartment area on the front passenger side as this thread stated: https://www.ford-trucks.com/forums/8...ntry-code.html
I found the sticker, which says "FoMoCo". The only 5 digit code I found was the "Date Code". That code didn't work.
Is there any other place where I can look?
Any help would be welcome.
Thanks.
Old 08-01-2013, 06:25 PM
JWC 3's Avatar
JWC 3
JWC 3 is online now
They use to be on the keyles entry module . My 04 mounty was that way . It was on the pass side rear behind a trim panel . Not sure on yours though . If you can locate the module it may be on it . Hope that helps .
Old 08-01-2013, 07:05 PM
jurban91's Avatar
jurban91
jurban91 is offline
Hm, I have no idea where the keyles entry module is situated. Ill try to look around on the internet. Hopefully someone on this forum can point me in the right direction.
Old 08-02-2013, 01:46 PM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
Depending on what you read, some say it was removed from under the dash after 05, then others point to the label you show in the thread you linked to. You may want to give it another try and make sure you are hitting the keys firmly in case one is sticky.
Old 08-05-2013, 06:51 PM
teepee542's Avatar
teepee542
teepee542 is offline
on my 12 expedition it was on the back of the module that is behind the kick panel on the passenger side. I remove the sill plate trim and the kick panel. I also had to remove the screws holding the module in so that I could pull it back and get the code. A lot of effort but it paid off in the end
jnobles06
08-25-2018 04:19 PM
kystangbanger
04-14-2009 06:18 AM
waterpourer
2004 - 2008 F150
10-30-2007 09:42 AM
scootergsxr03
2004 - 2008 F150
10-25-2006 02:05 PM
daimon1054
1999 to 2016 Super Duty
07-29-2004 07:34 PM
Quick Reply: 2009 Navigator - Factory Keypad Code
