1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
how the heck do i change my front turn signal bulb?
Old 08-04-2013, 04:28 PM
02 Super Duty Guy's Avatar
02 Super Duty Guy
02 Super Duty Guy is offline
02 f250 SD...I need to change the front corner turn signal bulb... How the hell do I get to it? I see the grey plug that I need to take off in between the bottom of the light and bumper but have no clue how to get to it..and does anyone know the bulb number?
Old 08-04-2013, 04:29 PM
02 Super Duty Guy
And its the driver side
Old 08-04-2013, 04:32 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Take the screws out under it and I think bottom first comes out. I did mine not long ago..
Old 08-04-2013, 06:27 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
There are two screws that hold the turn signal lens to the fender but sometimes access to those screws is obstructed by the bumper. If that is the case on your truck, then simply loosen the four bolts holding the bumper to the frame and it will drop down enough to allow access to the turn signal fasteners.
Old 08-04-2013, 06:39 PM
02 Super Duty Guy
I see the screws and can get to them..thanks guys I guess I should have looked harder lol
Old 08-04-2013, 06:54 PM
JToshi's Avatar
JToshi
JToshi is offline
Fairly certain the bulb is gonna be 3157, But I can be positive. Hope that helps.
Old 08-04-2013, 06:59 PM
02 Super Duty Guy
It does thanks guys
Old 08-05-2013, 08:54 PM
da X-man's Avatar
da X-man
da X-man is offline
My two screws are being blocked by my ranch hand. I tried, but I can't access it from the back. If I remove the headlight assembly, can I get it from the top?
Old 08-06-2013, 06:39 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,078 Likes on 2,148 Posts
nope. the screws are between the bumper and light, and there is no relation to the headlight.
i have a 24 inch shaft #2 phillips i use to access these screws.
harley3348
02-21-2011 12:08 PM
Fifty4F100
08-28-2010 09:47 PM
cjgeorge32
10-22-2009 11:32 PM
Loftatsea
04-22-2009 08:37 AM
Quick Reply: how the heck do i change my front turn signal bulb?
