'96 5.8 mild build recommendations
I have a '96 Bronco with 5.8L motor that is all stock, its a MAF motor with roller cam. I am looking for recommendations regarding camshaft upgrade and exhaust. Its a daily driver and just want to get a little more out of it. I will be running the stock heads and keep the roller lifters, dont want to use a flat tappet cam. Thanks for any input.
I decided to upgrade the exhaust first and am putting engine back together using original rocker arms for now. When I bolt them down I have little to no preload on the lifters. I have original cam, lifters, and pushrods so I called the machine shop and they said they just grind down the bottom of the rocker pivot blocks (not sure what they are called). I have never heard of this. I am thinking he cut the valves to short. What are my options now?
Rusty_S
03-06-2019 12:04 PM
jeffj2689
13
05-30-2007 07:00 PM
teflon_80
05-11-2003 02:38 PM
