Good evening. Supposed to be sunny Monday thru Wednesday. Have tomorrow and Tuesday off.
Had a scare. Thought the fridge had quit. We cleared the freezer out to the other ones. Checked the breaker and it was good. Tried outlet, dead. Seems like the breaker may have took a dump. Anyone know how to check it other than putting a new breaker in??
i do know there is a tool you can buy that you can plug into an outlet thatll pop the breaker... another way to test it to see if its functioning properly
Power problem solved. There is a generator transfer switches in the cellar closet. The boys went down to get helmets and evidently hit that circuit transfer switch. All good
