Cab Swap and the HF Gantry Crane
1961/66 F350 pickups came with 9' Express Flareside & Styleside beds. The Flareside bed was originally installed on 1953/60 F350's, the Styleside bed originally installed on 1957/60 F350's.
1961/66 F350's came with 45" opening radius front fenders that will also be found on the following:
1961/65 F100/250 4WD / 1966 F250 4WD // 1961/66 F100 2WD with optional 17.5" wheels / 1961/66 F250 2WD with optional 17.5" & 19.5" wheels / 1966 F100 4WD with optional 17.5" wheels.
C2TZ-16138-G .. Radiator Support: 1961/64 F100/250 2WD/4WD / 1961/66 F350/600 / 1965 F100/250 4WD / 1966 F250 4WD
What makes you think so? There's no such thing as an F350 only cab.
Originally Posted by Kscop
As it turns out, the cab DID off an F350.
In terms of the cab, I talked to the PO and he told me he had it on an F350.
That explains the battery box in the right spot for me.
He's also selling the dually rear end if anyone is interested..
The front clip was on the same F350 and from what I found out and what ND shared, it looks like I lucked out and this clip will work on my 4x4. There is the wrong inner fender on the RH side, but it should work.
1961/ F350 Fender used with 17.5 & 19.5 Wheels C2TZ 16005 (16006) - D
1961/ F100/250 2wd used 15/16" wheels C2TZ-16005 (16006) - E
So.. this was on an F350..
Also - I went old school and took some measurements from the new and old fenders. They are the same..
YAY!
Now for me to just find the time, and for the humidity to get below 99% and the temp to drop a bit..
I just went out to measure and about passed out..
YAY!
fastphil
18
10-07-2011 11:49 AM
rcav8or
21
07-14-2008 07:40 PM
Nathane
06-08-2006 11:11 PM
muscletruck7379
05-08-2004 01:24 PM
