Missouri Chapter Join Chapter , Leader:77&79F250
Hurry up! Summer's coming to a close! August Chat Thread
  #46
Old 08-03-2013, 03:44 PM
whiskey runner's Avatar
whiskey runner
whiskey runner is offline
just wanted to post a picture to prove i did get at least a little done this past week
  #47
Old 08-03-2013, 04:50 PM
cyclopsblown34's Avatar
cyclopsblown34
cyclopsblown34 is offline
Way to go RC.
  #48
Old 08-03-2013, 05:49 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Moderator & parts seller
Received 3,277 Likes on 2,435 Posts
Me to taking the grandson for a bronco ride and washing the dust off the tires and blowing the spider webs out of the carb.
Now we all are going fishing....
  #49
Old 08-03-2013, 06:14 PM
j20owner's Avatar
j20owner
j20owner is offline
Hi, still here, just don't have much reason to post much. Still slowly plugging away on the Jeep.
  #50
Old 08-03-2013, 06:15 PM
Grems4ever's Avatar
Grems4ever
Grems4ever is offline
Nice pictures guys.
The van is back up and running. The same rodent that ate the vacuum line also ate the harness to the cylinder head temp sensor. After a bit of fussing with it, I managed to get the connector rewired and the harness back in.
Tomorrow I have to do some yard work so the Dish Network guy can come in and put in the permanent Dish in the middle of next week. Our old system finally gave up the ghost and a the new one is going out in the yard so it can have a better signal. Hopefully that will get done quickly so I can turn my attention back to the camper. I really want to go camping again before the year is over.
  #51
Old 08-03-2013, 06:22 PM
Cerpindicular's Avatar
Cerpindicular
Cerpindicular is offline
anyone here a mower guru? My mower got stolen and i picked up a rider with a newer motor for stupid cheap but its got a few quarks (i did get the front mowed with though so it does work) that i need some help with its a Wards Signature series 2000 elite with a 14.5 horse brigs. The problem i am having is one for some reason in reverse it will through the belt if i hit a bump or in my case drop the well in a 10" hole and also two if i put it in reverse not only does it stick but the brake doesn't work in reverse i have to shut it down put it in forward then start it back up brake does work going forward. Also need to know where i can get a carb rebuild kit in springfield for the mower since i have to run it with the choke pretty much all the way out.
  #52
Old 08-03-2013, 06:28 PM
Cerpindicular
Oh you know I like red....looks sharp.
You misspelled pink again guess your getting senile in your old age ...happy birthmas.
  #53
Old 08-03-2013, 06:33 PM
Grems4ever's Avatar
Grems4ever
Throwing belts could be from mis-alignment or the belt being too long.
If you have the model number off the engine, you can look up the carb kit at an online retailer to get the part number. Once you have the part number, check with O'Reillys. I've had pretty good luck finding them there lately.
The shifting problem is a toughie, but it could be from the belt being too small. Most of these systems use slack in the belt as a clutch mechanism. Too small of a belt = the "clutch" not releasing enough for gear changes - especially in and out of reverse.
If I were closer, I'd come take a look at it...
  #54
Old 08-03-2013, 06:39 PM
Cerpindicular
well if your ever in springfield let me know and i will be more then happy to let you look it over. All in all even with its issues it did good mowing my front yard once i got it it up and going and i only paid 70 bucks for the thing. I ran into another issue apparently my guesstimating is not to good on size my mower won't fit through the gate to my back yard DOH! it also keeps chewing through starter drive gears but i think we figured out why and ordered a few different kits to compare to compare looks like it was missing a few parts for the bendix and drive gear so it wasn't working right
  #55
Old 08-03-2013, 06:43 PM
BORDERBUM's Avatar
BORDERBUM
BORDERBUM is offline
Cool RC! Nice work!
Rich, looks like fun! He will always remember that I'm sure!
  #56
Old 08-03-2013, 06:51 PM
Cerpindicular
thanks for the info grems i ran out and found the model number 287707 and think i have found the right carb rebuild kit. lol think it cost more then the kit i got for the bronco...figures
  #57
Old 08-03-2013, 07:50 PM
Grems4ever's Avatar
Grems4ever
Cerp - did you cross reference the number on OReilly's site?
  #58
Old 08-03-2013, 07:57 PM
1OldFordMan's Avatar
1OldFordMan
1OldFordMan is offline
Sounds like a good model #. You're probably gonna want the type & code too for a carb kit.
  #59
Old 08-03-2013, 08:50 PM
BORDERBUM's Avatar
BORDERBUM
http:// http://i1284.photobucket.com...psac9a3f6b.jpg
Is there not a extended piece for this that is for a lift? I'm trying to get Ol Big Red steering better....thanks
  #60
Old 08-03-2013, 09:26 PM
Cerpindicular
that link doesn't work what are you trying to find
Quick Reply: Hurry up! Summer's coming to a close! August Chat Thread
