'02 Expedition Air Shocks Lowering
For the last 2 days, the shock air bags have been empty after sitting overnight. Resetting the switch under the passenger dash turns the compressor on and they refill.
We've never had any problems with the suspension until now.
I know there is a switch to sense the height of the vehicle and kick on the compressor, but I'm not sure how to test it and see if that's the problem.
Any ideas where to start?
Thank you,
Jason
Thank you,
Jason
you can start by going to the local junkyard and getting 4 of the stock coil/springs off an Expedition.......I got mine for $200 and put them on myself( Expy 2005)........I don't notice a difference in the ride and I never have to worry about those stupid air shocks
they are great when its a brand new vehicle but are nothing but trouble later on
There is a reason why you don't see air suspension on Fords newer trucks and SUVs.....PITA!!!!!!
What happens if you get in, start it, and shift to Drive, does the compressor kick in and pump up the system?
That switch is not a reset switch, it's a simple on/off switch. By turning the system off and then on, you are resetting the air suspension control module. I would suspect the module as being the source of the problem. If it was a height sensor, then the compressor would never turn on because it would have no signal from the sensor telling it to pump up the air bags.
seventyseven250
1997-2006 Expedition & Navigator
07-19-2010 10:47 PM
