has anyone ever "slammed" a bronco?
It's an interesting concept, I'll give ya that. Although I love the 78-9's for their 4wd capabilities, I'm willing to open my mind. I'd like to see the ending outcome of this little street rod project ONLY if you don't "slam" it and put big chrome rims on it. Then... then I will be disappointed.
Slammed bronco sounds terrible imo, but I have no room to talk, threw a 390 in a suburban and welded powered by ford over the cheby emblem lol. If you could find a 2wd truck or Bronco that would be easiest. I do like the idea of taking a newer style exploder suspension to do it. That way you could still have some capability.
Not sure how your build is going to work with the Lincoln parts and Crown Vic parts, but have fun!! My buddy was going to 2WD his Bronco when he busted the front end. He took it all apart.......and then he got married!! The Bronco got put into a container and sent overseas! I'm pretty sure you have to change the steering gear....they are different between 2WD and 4WD. I think they turn opposite directions!! How that plays into the Crown Vic front end......don't know!!! Your IRS Lincoln rear end....you might want to measure it to see the width. Custom bags on the 9" rear might be a little more feasible......but who knows!! Have fun!
Yea....I think......my memories of a Crown Vic aren't good ones!! I think they are rack and pinion. A rack and pinion would definitely make for quicker steering!
Good read on the Crown conversion.
https://www.ford-trucks.com/forums/1...-vic-swap.html
If you want to go with more of a "Gasser" design dragster look a simple axle can be built that would consist of a tube with dana 44 Cs welded on and Ford knuckles out.
Uses the stock steering. I would replace the coils with leafs and a track bar though.
75BigBlock
13
09-13-2017 08:57 PM
GM4WALLS
13
11-19-2013 04:25 PM
