6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
EGR Warranty?
Old 07-23-2013, 05:01 PM
captainkbt's Avatar
captainkbt
captainkbt is offline
EGR Warranty?
Had an issue this morning. Been noticing a slight loss in power the last few days when accelerating. Not much, but enough to notice. This morning I went to pass a vehicle and the vehicle gave a shutter like it lost acceleration power for a split second. It was enough to alarm me and I thought "what the hell was that." I accelerated a few more times to test and it seemed a bit sluggish. Then the engine light came on and I pulled over immediately and checked everything....and all was good. The Ford dealership was right down the street so I took it in. Service called me and said diagnosis was "one" bad EGR valve. Cost....$850 to replace. And he said its not covered under my "Extracare" Ford extended warranty.
Question: Is this covered under Ford Emissions Warranty? It's a 2008 250 with 83k miles AND Ford "Extracare" extended warranty. I thought emissions went to 100k.
What the heck did I buy an extended warranty for if crap like this isn't covered?
Old 07-23-2013, 06:34 PM
Gearitis's Avatar
Gearitis
Gearitis is offline
Nope, not under ExtraCare
Personalized Vehicle Owner Information
You would need to have had the Premium ESP to cover Emission to 100k.
Old 07-23-2013, 07:48 PM
senix's Avatar
senix
senix is online now
Received 1,400 Likes on 997 Posts
did your 5 year/100K motor coverage expire as well?
Have them look the part number for the EGR valve itself up to verify coverage.
Old 07-24-2013, 01:18 PM
captainkbt's Avatar
captainkbt
Don't know what the original sale date of the truck is. I purchased it 1 1/2 years ago as second owner. It has 83K miles now. I thought EGR went to 100K miles on emissions.
Thanks.....
Old 07-24-2013, 01:42 PM
senix's Avatar
senix
senix is online now
Consult the owners manual but I don't think so.
Old 07-24-2013, 05:42 PM
Gearitis's Avatar
Gearitis
Gearitis is offline
From what I understand, it is under the 5/60k. Emissions do not make it to the 100k level. I had a cracked DPF at 56k. Ford service told me that I was lucky that it was under the 60k mark as its not covered over that. I feel that EGR falls under the same unless you have the Premium ESP and still the DPF is not covered but EGA and related components are covered.
Old 07-24-2013, 06:01 PM
senix's Avatar
senix
senix is online now
DPF for MY 2008 is 100K/5 yrs.
But only 2008.
Old 07-24-2013, 07:25 PM
Gearitis's Avatar
Gearitis
Gearitis is offline
But only 2008.
I am beginning to think that these Ford service centers make up their own rules. If I can still find the old invoice as its been 2 and a half years, it stated the 5yr/60k warranty. I wonder if that is just default wordage....
Old 07-24-2013, 07:40 PM
senix's Avatar
senix
senix is online now
I am sure it was..just refer to the owners manual and it indicates 100K on the dpf.
But 2009 and up is only the 60K
Old 07-24-2013, 08:47 PM
captainkbt's Avatar
captainkbt
Yep........
Page 21 copy and pasted from 2008 Super Duty Warranty Guide
List of Parts Covered for 5 Years or 100,000 Miles (whichever
occurs first) by Emissions Warranties for Diesel Engines
Air Flow Sensor
Air Induction System
Catalytic Converter (including
Diesel Particulate Filter and
Diesel Oxidation Catalyst)
Cold Start Enrichment System
Electronic Engine Control Sensors
and Switches
Electronic Engine Control Unit
(ECU)
Emissions Label
Exhaust Gas Recirculation
(EGR) System
Exhaust Manifold
Fuel Injection System
Fuel Injector Supply Manifold
Intake Manifold
Intercooler Assembly - Engine
Charger
Malfunction Indicator Lamp
(MIL)/On-Board Diagnostic
(OBD) System
PCV System and Oil Filler Cap
Supercharger Assembly
Throttle Body Assembly (MFI)
Turbocharger Assembly
Important Information About List of Parts
Also covered by the two emissions warranties are all emissions-related
bulbs, hoses, clamps, brackets, tubes, gaskets, seals, belts, connectors,
non-diesel fuel lines, sensors, and wiring harnesses that are used with
components on the list of parts, above.
Concerning parts that should be replaced on a certain maintenance
schedule: these parts remain under warranty until : (a) the first replacement
time that is specified in your Owner Guide and the Scheduled
Maintenance Guide; or (b) the time or mileage limits of the Federal
Defect and Performance Warranties (whichever occurs first). Your Ford
Motor Company dealer maintains a complete list of parts covered by
emissions warranties. For more details about the specific parts covered
by the Emissions Defect Warranty, contact your dealer.
I guess bottom line is this. If my truck was put in service prior to 7-23-08 Im screwed.......its been over five years. If its later......Im good because OD is at 83K.
Old 07-25-2013, 06:30 AM
Gearitis's Avatar
Gearitis
Gearitis is offline
Got it! I would have thought that with the VIN and part number, Ford would have come back showing the warranty on this. Oh well, it was covered at 56k so no skin off my nose that time. I was unaware of the change in the 2009 year. Got edumacated again by this forum.....
Old 07-25-2013, 08:59 AM
captainkbt's Avatar
captainkbt
IM PISSED!!!!
Just got home from Planet Ford (Spring TX.) picking up my truck from service. Service said I owed $867 to replace the "EGR Valve". I directed the service guy to page 21 in my 2008 Warranty Guide where is specifically states under the Emissions warranty...."Exhaust Gas Recirculation (EGR) Sytem" is covered to 100K miles for diesel engines" that I C&Ped on post #10 above. I had it in my hand and specifically pointed it out.
NO DICE, this dude wasnt having any of it. I said..."its right there in black and white". He said "well.....this is the EGR valve (part # 8C3Z-9D475-D), its not covered" . I replied...."the warranty book says 'EGR SYSTEM is covered to 100K miles',are you telling me with a straight face that this EGR valve isnt part of the EGR system?" and I also pointed to the paragraph below that says all parts accociated with those systems are covered. He said his hands were tied. The service manager was sitting right behind him listening and watching the whole conversation and this service guy even went and discussed it with him. Still nothing. I had to pay $867 of my hard earned money for a service or product that I was sold as warrantied. Unless Im missing something that I am not aware of or a fact that I am ignorant about........That my friends is deceptive trade practices.
You sell customers a product and tell those customers, such and such is covered in your warranty and then not cover it when it when that product fails! THATS BS!!!
To any of you potential Ford customers.....buyer beware.
Old 07-25-2013, 09:05 AM
captainkbt's Avatar
captainkbt
Refer to the "owners manual" like I did? I had it in my hand highlighted with yellow highlighter and they didnt cover it.
Old 07-25-2013, 09:06 AM
senix's Avatar
senix
senix is online now
Ford Rep help
Submit this to our Ford Rep Crystal via pm with vin #.
there is also info in your owners manual on how to handle this issue.
Old 07-25-2013, 03:34 PM
FordService's Avatar
FordService
FordService is offline
Official Ford Rep
Originally Posted by captainkbt
...Just got home from Planet Ford (Spring TX.) picking up my truck from service. Service said I owed $867 to replace the "EGR Valve". I directed the service guy to page 21 in my 2008 Warranty Guide where is specifically states under the Emissions warranty...."Exhaust Gas Recirculation (EGR) Sytem" is covered to 100K miles for diesel engines"...
As senix has suggested, captainkbt, shoot me a PM with your information so I can look into this for you and see how I can help. I'll need your VIN, dealer, mileage, daytime phone number, and full name. I'll keep an eye out for your message.
Submit this to our Ford Rep Crystal via pm with vin #...
Thanks for bringing this to my attention, senix!
Crystal
Quick Reply: EGR Warranty?
