Aerostar Ford Aerostar
Exhaust Flange Bolts Nightmare
Old 07-21-2013, 11:34 PM
CourierYVR's Avatar
CourierYVR
CourierYVR is offline
Hiya, I am in the planning process of replacing the entire exhaust system up to the front exhaust flanges on my 93 3.0L shorty Aerostar. The primary reason is because the front catalytic converter was destroyed by an Esso/Exxon car wash which sprays cold water under the vehicle. As a short term solution, the front catalytic converter was replaced with a straight through pipe. Also, the Flex pipe has a growing hole where the hanger "was" welded. It is currently held in place using a wire coat hanger and muffler patch compound. Also, I need to get this done soon because the Environmental Police says it must pass the "clean air" test.
I have purchased all of the parts, stainless steel except for the aluminized steel tail pipe, but not the exhaust flange bolts. I cannot find them anywhere. I would prefer to replace the rusted exhaust flange bolts and nuts with stainless steel bolts and nuts.
Today, after soaking the flange bolts with PB Baster overnight, I managed to remove one of the nuts on the manifold down pipe extension (drives side) using a breaker bar. Wow! What a cracking noise it made! It seems to be a 9/16" nut. Anyway, the other nut looks like it has been under the ocean alongside with the Titanic. So far, there is no chance of removing it without stripping the nut or breaking the bolt. I will try the heat and wax method next week, but looking at it now it does not look promising.
What I really want is a brand new set of exhaust flange bolts and nuts (Stainless Steel please!).
Where are they!!!??? Is there anything available that can be substituted?
Old 07-22-2013, 08:02 AM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
Once you know the diameter and thread pitch, you can easily find what you need. Unfortunately I do not know off hand what that is. I assume you are talking about the studs off the manifold? If its just the one on the downpipe section, just break it and put in new ones.
Old 07-24-2013, 07:23 PM
asavage's Avatar
asavage
asavage is online now
A blast from the past . . . I captured this pic in 2002, eleven years ago.
Click here for larger
That shows double-ended studs on the pass. side, and bolts on the driver's side. From what I recall, they were not all that special (other than removing them the first time; I always use anti-seize on exhaust stuff, so after the first time, they come off without problems). Metric, or course, and I believe I found some 10.8 or 12.8 replacements.
Old 07-25-2013, 08:42 PM
CourierYVR's Avatar
CourierYVR
Hey! That looks exactly like my 93 exhaust but without the Flex Pipe detail.
Thanks for upping the photo Savage. That's them Exhaust Flange nut/bolts.
I am going to try using an impact driver to release the corroded nut.
The other three nuts are in good shape, it's the bottom one that is toast.
Old 07-26-2013, 01:27 PM
asavage's Avatar
asavage
I've had pretty good luck using a Dremel and a 1/8" carbide burr to cut away a lot of the rusted nut, then spray again, then grab the remains with needle-nose vise grips, but sometimes you have to cut it off flush as you can, then drill it out from the bottom. I don't bother with trying to drill exactly on-center on in-frame jobs like these, I just go oversize and plant a coil insert in the manifold, and use a new bolt. There's lots of ways of dealing with it, but if you can remove it without cutting, that's best of course.
Depending on access, I've often used a torch (not propane) to make the manifold's ear red-hot, then the stud or both almost always comes right out, but sometimes you can't get that much heat on the flange's ear when it's installed.
Old 07-27-2013, 10:08 PM
CourierYVR's Avatar
CourierYVR
Well... my biggest fear came true. The bottom driver side rusty exhaust flange nut broke off, and I'm pretty sure the passenger side bottom nut will also break off. The top nuts on both sides of the exhaust are in good shape.
While I was looking at the exhaust flange bolts, It got me thinking... why not remove all of them, and replace them with readily available stainless steel bolts, nuts, and washers? See example pic below:
Old 07-28-2013, 06:35 AM
Kruse's Avatar
Kruse
Kruse is offline
That will work just fine, especially on an Aerostar where the fix will probably outlast the vehicle. I should have done that on my daughter's Mustang instead of chasing down some exhaust parts that were discontinued by Ford and buying them from all parts of the country.
Old 07-28-2013, 11:51 AM
KhanTyranitar
You should use studs, not bolts. The main reason is that if a nut strips out, you can still extract a stud. If the nut won't turn, chances are the entire stud will unthread, giving you 2 ways to remove it. With a bolt, you have only one option, if it strips or breaks, you have to cut it off and resort to extraction.
Old 07-28-2013, 11:45 PM
CourierYVR's Avatar
CourierYVR
Here is a pic of my drivers side broken Exhaust Flange Bolt:
As you can see in the above pic, the shank of the primary section of the stud rusted away. But the secondary shank that attaches to the manifold down pipe coupling, or the drivers side manifold extension pipe coupling, is still intact and removable. I am having the same exact problem with the passenger side flange bolts, the top bolt is removable, while the bottom bolt won't even nudge while using an impact driver, PB Blaster, and a propane torch. The bottom bolts on both sides are to be considered sacrificial lambs. They won't budge without the use of a breaker bar. The breaker bar brakes the outer flange nut off, which leaves the inner bolt stud intact. The inner bolt and stud is more heftier, which makes it easier to remove, and it is also more protected from the environment because it is isolated.
I am now in the process of rethinking. I have considered the use of studs but I cannot figure out the tread count per inch (I think it is metric 14), nor the exact width. They are that corroded. I now think, why not just get a couple of 2" x 3/8" SS bolts and complimentary SS flange nuts. I do realize SS bolts are not as strong Grade 8 bolts, but at the same time I don't think these Ford Exhaust Flange Bolts are NOT anywhere near Grade 8!
This is just an exhaust pipe connector, not like a cylinder head!!!
Old 07-29-2013, 08:02 AM
KhanTyranitar
Yeah, I don't think the strength of the fasteners is an issue, corrosion resistance is the biggie.
Old 08-04-2013, 12:49 AM
CourierYVR's Avatar
CourierYVR
I finally scanned a pic of the exhaust flange bolts from the service manual:
The stud is N802110, and the nut is N800152. Part number sometimes needs the suffix "-S".
I do NOT plan on purchasing these stock Ford parts. I do not want them for the reason that they cannot be removed after usage.
I went to Home Depot, in order to figure out the bolt size and thread count. The closest match was M12 and 1/2", but neither of them fit perfectly on the rusty bolt end.
So I am now settled with my original plan of using 3/8" x 2" SS bolts:
Except... they will be installed upside down from my original plan.
Old 08-05-2013, 07:51 PM
CourierYVR's Avatar
CourierYVR
It is Done!
Here is the Old Exhaust:
Here is the 3/8 x 2" bolt:
And I discovered a missing manifold stud:
Tailpipe:
The new MagnaFlow Direct Fit rear CAT pipe is not aligned properly:
Rear Muffler connection does not have enough room for a band clamp:
Old 08-05-2013, 09:59 PM
KhanTyranitar
Good to know, but no one asked me. Magnaflow cats are junk. All emphasis is placed on cosmetics, and the fit is terrible, and the cats are known to fail prematurely.
Old 08-06-2013, 03:20 AM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
Nice work. Did you put anti-sieze compound on the bolts?
I used stainless hardware on one of my cars, but it had flanges on both sides, so it required someone/something to hold the head of the bolt while I tightened the nut on the other end.
Old 08-06-2013, 05:32 AM
CourierYVR's Avatar
CourierYVR
Well that is weird. I have heard nothing but good reviews for Magnaflow cats.
Although, they did send me an email requesting to review their product. It has not yet been published on their website. And it probably won't be because they have zero reviews for any of their products.
Here it is:
The stainless steel quality and reasonable price far surpass anything out there.
But the following minor concerns are why I did NOT give it the deserved 5 stars:
1) Accommodating Stainless Steel Band Clamps. The front Y-Pipe tail end needs to be a bit longer where it connects to the CAT pipe section, and the CAT pipe section where it connects to the front Y-Pipe needs to be as short as possible in order to have enough pipe length on the front Y-Pipe, with out interfering with the Oxygen Sensor and cross pipe, in order to install Stainless Steel band/mega clamps. I managed to install an SS band, but it was because I pulled the CAT pipe section backwards a little bit. Also related to the above, is reusing the Ford factory pipe heat shield. The heat shield cannot be transferred when using an SS band because there is not enough pipe length on the Y-Pipe to clamp it on using a couple of SS screw bands.
2) Flex Pipe Alignment. The tail end of the CAT pipe section is a little bent off by a few degrees in order to connect it to the factory Flex pipe properly. The tail end of the CAT pipe section is pointing a bit downwards, instead of pointing directly at the Flex pipe in the eye. No matter how much I twisted the CAT pipe section, in would not align it self with the Flex pipe. This puts abnormal strain on the Flex pipe.
Other than the above, a fantastic product that not only looks great, but is also solid.
Quick Reply: Exhaust Flange Bolts Nightmare
