1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
04 Upfitter switch fuse locations
Old 07-19-2013, 07:16 PM
xmontex4's Avatar
xmontex4
xmontex4 is offline
Wink 04 Upfitter switch fuse locations
Hey guys, I installed my upfitters on my 04 and i wired up two sets of lights one set to switch 2 and the other to switch 1, I have a 5.4l if it makes a difference. Switch two works however switch one does not. I put a 15A fuse in every open slot available in my fuse panel, I thought that only switches 3 and 4 had to be powered else where? Does the circuit for switch 1 not exist in my fuse panel and it needs to be powered else where? Anything you guys know is greatly appreciated I've been trying to find this out for a few weeks and I haven't really gotten anywhere.
EDIT: Don't know how the winking face got in there lol
Old 07-19-2013, 08:54 PM
dscabra's Avatar
dscabra
dscabra is offline
Old 07-19-2013, 11:39 PM
xmontex4's Avatar
xmontex4
xmontex4 is offline
Yes thank you I will try those fuse locations tomorrow! If I recall correctly fuse 2.3 and 2.5 have no circuit in my junction box do I will have to re locate those wires.
Old 07-20-2013, 10:36 PM
xmontex4's Avatar
xmontex4
xmontex4 is offline
Unfortunately the locations did not work, I will pull the fuse panel and test the wire where I connected my lights.
BrotherAndySLB
03-30-2012 06:00 AM
alhauger
08-04-2010 01:56 PM
rickppph
Electrical Systems/Wiring
09-14-2006 02:54 PM
happycamper116
1997-2006 Expedition & Navigator
03-04-2005 05:15 AM
bronco351
1978 - 1996 Big Bronco
11-04-2002 02:33 AM
Quick Reply: 04 Upfitter switch fuse locations
