A manual clutch question
I have a question Re: the frame-clutch-pivot-stud center-line relative to the bell-housing.
The back-story: My 86' DD has a hydraulic clutch and has some issues regarding a weak firewall. In the process of an engine change I have decided to "fix" this problem by reverting back to a manual clutch arrangement utilizing parts that I have. My reasons for doing this go deeper than this discussion merits..so since I AM doing this..
As near as I can determine the center-line of the clutch-pivot-ball on the engine is about 1-1/8" forward of the bell-housing-plane.
Can anyone, (hey AB) confirm that the frame stud is 90 degrees (perpendicular) from the engine?
If I had one parked near me I could see this of course but I don't.
The salvage yards that have any of these either no longer have a bell, or frame mount, or are either to unsafe to crawl u'neath to double check...
So, I thought I'd pose the question..
Kinda boring..I know but..thanks anyway for any input...
I'll try to catch up
I actually have that part,(although don't let any spares get away from you if you run a manual clutch)
It's the location on the frame for part "7507" (the frame-plate-pivot-ball) in number dummy's picture that I need to locate the holes for. (My 86' didn't come with any holes.)
I have in my possession a "7507 I purchased from a salvage yard that bolt holes on 5" centers. I'm not sure the years came with the same "7507" with mount holes accordingly but I assume so for 80"-83"
I actually post this question on the F150 side of FTE as well and Gary was kind enuf to take a pic of an 82' frame with some holes.
I looked at an 84' today for another reason and it looked like it had holes on a longer center than 5" so, AB, what are your thoughts of the holes centers on your "84? Also if you still have that frame pivot ball installed, is it directly perpendicular to the ball on the block? I would assume so, Just don't have a reference in front of me...
Thanks all for the input, and as in any project, good info just helps to sort things out...
Also if anyone has a manual clutch bell un-cracked, I'm looking for a SPARE, along with any of the other necessary related parts. I have a complete set from an f150, not sure which year, but I have decided to collect some spares of all of the related stuff..as others have said...Things wear out, and break...
good input
I AM working on a heims joint solution for the rod as well...thanks for the input for sure.
lvin4jc
22
11-20-2019 08:49 AM
6978sghfbjklgdfsjhkl
07-21-2013 09:30 PM
