Rear Mount Turbo 1997 4.6L
I've been reading some of the posts and have a few questions regarding this setup.
Background on the truck. Low km 1997 4.6L Expedition, stock engine with the following upgrades; Throttle Body Spacer, K&N, SCT programmer, and just ordered headers.
I'm looking to reduce the engine load on my 4.6L with the addition of a Turbo, hoping for a little MPG gain as well.
The rear mount is intreguing as it's out of the way, and will give me that little extra. Currently when I tow my trailer I have a pretty good engine load, and would like to reduce it.
Goals - As this is a stock bottom end, I am looking for 7-9 psi, and a reliable truck. Not something that will be used for racing. I tow a trailer, and haul the family around.
So question period;
- When you rear mount a turbo, is it possible to route the intake up, as I assume the closer the better, what is the drawback?
- Skidplate? I live in Canada, and am concerned that snow, debri will hit the Turbo, or the snow will crack it.
Cost is a concern, so I will be building this myself. So, reference material or recommendations are appreciated.
So question period;
I want a turbo engine bad, and I have looked into the rear mount. Luckily I got to meet a couple of people who have it along the way.
The lag is not that bad just slightly more then a normal set-up.
As for water in the intake you can put a filter sock over it, and that keeps water from just getting it. Plus also sand and excess dirt.
Turbos are designed for being hit with water, and not crack. If you have a turbo Saab water will still hits the turbo, but its turbo is a few hundred degrees hotter then a rear mount.
I don't know enough of how snow collects under a vehicle to say anything, but you could probably block off an area sufficiently for the turbo.
Lastly put it as close to you engine as possible. This way you reduce lag greatly by keeping the thermal efficiency high.
trevorrules
06-21-2015 04:16 PM
