1990 f350, 460 v8
1990 f350, 460 v8
I have problems with the fuel circuit , have checked relay,
Pump,signal when cranking. Replaced pumps, relays,
ground wires. Can only get 7.5 volts to the pumps with the test point grounded. Is there a way to check the computer?
Should I just replace? It did crank a few times with the ground at the test point but now the voltage is low and pumps will not come on
mwilliams0326
44
11-11-2015 02:42 PM
galeggs
10-06-2013 07:51 PM
Randy 32
07-18-2013 10:06 AM
case310350
12-15-2006 04:22 PM
