Fuel Tank Removal - 2008 and up Superduty
Has anyone dropped their fuel tank on the 08+ superduty models? Any videos, pictures, instructions, and or write ups to be had? This is on a 6.4 diesel, but from what I've read, it may very well be the same tank in both the gas, and diesel models. I found a Titan Tank install on a 6.7 model..but I think I read somewhere that those are different tanks and setups.
I've been throwing the dreaded P0088 code: High Fuel Rail Pressure. Physical symptoms, while not always present at the time of throwing the code, are similar to that of of limp mode when running low on fuel..a sputter effect almost, but not consistant if you know what I mean. This happens mostly in the lower gears, through acceleration. It's erratic at best, and is exaggerated when hauling loads....in fact it usually only happens when I'm hauling loads, or the fuel filters have over 4000 miles on them. It typically only happens when I'm running low on fuel (under a quarter of a tank), and or, right after a fuel up (rare). If I change out the filters, it's good for about 1000-2500 miles before it starts acting up again. I've only been going 5000 miles at most on fuel filters for the last 20k-25k miles, due to this issue (I put on a lot of mileage in a short period of time during the spring, and fall.). Maintenance has never been an issue on this truck. I currently have 178k on the clock.
I've read the stories about the HPFP, from my experiences, and with the randomness of it..I don't think that's the issue. I've elected to drop the tank, and clean it out. I was going to remove the HFCM, clean it out, and change out the gasket, but instead I just bought a new one.
I personally like to over analyze things, and go over things in my head a hundred times over before actually tackling a project on hand, no matter the size of it. Hence the request. Any help is appreciated - Thanks!
This lower filter had about 2500 miles on it. The top one was clean as a whistle. From what I've been told, a blockage and or inconsistent fuel flow will result in a P0088 code.
That's kind of a hard question to answer where it fluctuates so much. At idle it sits at just over 5k. Average pull is 14k- 16k ish, it goes up to 21k-23k under a heavy load, and hard acceleration on an incline. The highest I've seen it is 26k and it was only there for a split second on a peak.
with you putting that many miles on i would guess your not getting your fuel from one single place right? otherwise id say mayeb try another rest stop. next i dont think its as big of a deal on fuel filters but i could be wrong, are you using ford filters? lastly are you running biofuel? i know i have read when they built these engine they did not design for more than B5 i think
like cheezit said tho with the code P0088 the High Pressure Fuel Injection Pump is the number 1 fix followed by have as many fixes of updating the pcm which like you know being tuned that's not the case. i guess like your original thoughts cleaning the tank might be your best shot as it runs better after new filters. if you do get it cleaned out make sure you let us know how it goes
I mostly use Pilots / Flying J's when I'm on the road, I'm not sure what they run. I try to stay clear of T/A's as a principal, but I was at one a few months ago (not by choice), I used the front pump with the cars, but when I went to get the nozzle it said bio diesel on the badge..so I went around to the truck isles out back, when I went in to have them swap the credit to the new pump, she asked why, her reply was it was all bio diesel. I'm not sure if she knew what she was talking about, or not, there wasn't any badges out back displaying it, and I was on fumes, so I didn't have a choice. It didn't seem to effect it in the least. I also run octane boost, not always Ford, but it's in there.
you're spot on with the tank being the first target. I went to the dealer, they read my screen on my tuner, and then came into the waiting room with an estimate for replacing the hpfp a few minutes later...they didn't test drive it, or so much as pop the hood. I had teh damn keys in my backpack the whole dam time. I'm not going to the extreme of changing the pump because the dealer says so. Yes, it's a common issue, and yes the TSB does indicate that as being the resolution, but it's not the only thing that makes that code pop up. Just because it's more probable, doesn't make it so..this is what infuriates me about Ford..not that it should surprise me. I did order a new HPFP ( I found a steal of a deal), but hopefully I can re sell it soon! The last time I was at the dealer and my DOC pipe went, they wanted to take the cab off, and charge me $1387 for a $227 part. I happen to be on the road at the time, so I limped home with the intention of having my dealer do it when I got there. I got to looking it over once I get home...cab off...tranny out?...I don't think so. I called up Rudy's and ordered a block off plate with a welded in bung for the BP sensor. The EGR coolers were already gone. It arrived 2 days later, & me and my 15 year old son tackled it in the driveway, 2 hours later we were putting away tools and cleaning up. $23 vs $1400...yup, get right on that Mr. Dealer; lesson learned.
I'll update as things progress...and I stop procrastinating.
The bowl up top is always clean. Like an idiot, I ran out of fuel on my last trip, I tried pushing it to a truck stop rather then stopping at a ma and pa place. Anyway, I had to purge the system, so I popped the upper one out, even sucking the crap off the bottom of the tank, the bowl and upper filter were clean. I had just changed the filters at the time, and only have about 3800 miles on them now, so I haven't' gotten around to changing them out yet. I'm pretty sure I know what I'll find in that lower housing.
