speaking about Bed Sides !
Old Jun 12, 2003 | 06:37 AM
Jim VA.'s Avatar
Jim VA.
I just finished crusing a few posts and ran across a comment by Fender's about bed sides,and how much Time and Money put in them and still are not quite satisfied with the results. I too am contemplating repairing the stock bed sides even though very little of them show once the fenders are installed.the inside of them is another story. At $250 plus $30 packing and $ ? freight each I don't know if my wallet will take it! Has anyone ever tried to save the upper rail (which are in good shape)and make a new side out of new sheet metal,either by a lap joint and spot welding to keep warpage down? Or should I bite the bullet and buy new . Thanks in advance
Old Jun 12, 2003 | 07:05 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Jim,
I think it depends on how far you plan to take your truck. If you are building a non-show truck and driver like me, then try making your own bed repairs. If you plan to build a show truck, you probably ought to go ahead and bite the bullet...just my opinion.
Old Jun 12, 2003 | 09:08 AM
fatfenders's Avatar
fatfenders
Jim
Ya, What Vern said. What are we building here? A show truck needs new bed sides. I don't much care about showing my truck, but I want it to look like one at any angle, from 20 feet away anyway. I think bedsides are one of the better values available to us. That's a huge piece of your truck for $250. Depends on what your time is worth and how perfect the end product has to be. Most people would be proud to own my bedsides now. But I have a hundred hours in each side and they're worth $50 each used. HMMMMM, gonna need some Enron math to get this one through accounting.
BTW, there are 130 spot welds to repair in my brand new tailgate I got at PF. I think there may be a hole in my new parts/save time theory already.
Old Jun 12, 2003 | 06:37 PM
Purple55's Avatar
Purple55
[QUOTE]Originally posted by Jim VA.
[B]I just finished crusing a few posts and ran across a comment by Fender's about bed sides,
He's got a comment about everything,doesn't he?
Motor Mouth!
My box sides needed very little work on the outside,but the inside is a different story.Very wavy,plus,I made tubs and I don't want to spend 100 hours per side making it baby-butt smooth.So I'm planning on going the Rhino-route on the inside with the exception of the oak floor.
Greg
Old Jun 12, 2003 | 08:36 PM
fatfenders's Avatar
fatfenders
"He's got a comment about everything,doesn't he?
Motor Mouth!"
You hurt my feelings Purple! Here's one more comment for you then I'm done posting for the night.
Rhino, Oak and tubs?
Nice combo Greg. And how about a nice yard sale fresh aluminum topper to finish it off.
Old Jun 13, 2003 | 05:54 AM
Jim VA.'s Avatar
Jim VA.
Gentlemen; Thanks for your comments. I just got off the phone with Mark,@ F100 connection, and we all agree I guess, that after spending all that time and labor on everything else,I should install New bed sides. I do not plan to have a trailer queen but like Fender's,I would like to have it look good from all angles.also it's a lot less work. Thanks Jim VA.
Old Jun 13, 2003 | 06:50 AM
tgregoire's Avatar
tgregoire
Have any of you guys checked with a local sheet metal shop? The hard part for these shops to do is to roll the top. I wasn't concerned with the roll as I was doing a custom bed. I had the 2 sides, the front panel, the stake pockets, the 4 filler panels and a roll pan bent for about $275 (for all of it). There are pics in my gallery of it.
Just a thought!!
Old Jun 13, 2003 | 08:39 AM
bobj49f2's Avatar
bobj49f2
The rail part of my bed, the tube like part, was bent up pretty good. I cut the whole thing off of both sides and left about an 1/2 inch so it formed a somewhat "V" channel. I then welded 3/4 black pipe to. I used a step drill to thin the rear end of the pipe to make it look the same thickness as the original metal. This will help with the problem of having a sheet metal not being able to do the roll for the top edge of the box.
I am sure the wall of the pipe will be more dent resistant than the original thin sheet metal.
Old Jun 13, 2003 | 02:04 PM
fatfenders's Avatar
fatfenders
"Have any of you guys checked with a local sheet metal shop?"
Yes I did, and they wanted $225 to make a front bed panel. I thanked them and told them not to bother with the side panel bid. $275 for everything is a steal.
Old Jun 13, 2003 | 02:05 PM
tgregoire's Avatar
tgregoire
Guess I got REAL lucky!!!
Old Jun 14, 2003 | 04:55 AM
GreatNorthWoods
I went to a sheet metal shop for my boxing plates. I took some cardboard templates and they cut them out of 1/8 inch plate...only cost me $25. It saved me a lot of time and grief and I thought I got a good deal...
Old Jun 17, 2003 | 11:55 AM
FOWL1's Avatar
FOWL1
I saw a truck in P.F with wood bed sides. I have a '55 F-250 (8 foot bed) that the previous genious cut a foot and a half off, to make it look like an F-100. It's tough to find bed parts for the longer beds and I paid $750 for a '53 to use the sides off of. I thought the wood bed sides idea was unique and I thought it looked pretty good. I think it was butt jointed boards and stained so it matched the floor and the fenders mounted right to the wood. If you're doind a low budget build, like I thought I was going to do, you might consider using the wood. If nothing else it may get you on the road until you get the money together. I wish I would have thought of that, like I said, just to get me on the road.
Old Jun 18, 2003 | 05:42 PM
Scot's Avatar
Scot
My bed sides and front were built at a sheet metal shop out of 16 ga. They used 1 1/2 square tubing for the tops and MIGed the seam. Works good.
