Why you want to upgrade your TS Trans Filter
#136
#137
Scott
#138
#139
Just, did this upgrade 2 weeks ago now, couldn't be happier. Ended up replacing the valvebody/solenoids with a rebuilt unit at the same time.
Just in case the P/N's get lost in this thread here they are again:
*Genuine Ford Transmission Oil Pan 8C3Z-7A194-B
*12 pack case of Motorcraft Mercon SP transmission fluid (mine only took 9.75qt to refill)
*Motorcraft FT-180 Transmission Filter
I left my spin on filter installed for the record, I have not seen over 175F in the transmission fluid once in the past 2 weeks of towing a trailer/moving my house.
#140
There probably was some fluid in the valve body/solenoids -- most folks are putting about 9 qts in with a new filter and more like 8 if you just dump-n-fill...
#141
Thank you for the oil filter P/N, yep indeed there was what seemed like a lot behind the valvebody which would account for the extra fluid.
#142
#146
I'm not trying to bust you but I spent a ton of research on the subject and Ford did recommend LV in place of SP but that didn't last long as they started to replace transmissions. The last I knew was SP is the fluid and no others in the 5 speed transmission.
Motorcraft® Transmission Fluids ? The Official Ford Parts Site | FordParts.com
Read the specs on LV and on SP. The SP is designed for Torque Shift transmissions.
Is it worth the gamble to use the cheaper fluid?
#147
Motorcraft® Transmission Fluids ? The Official Ford Parts Site FordParts.com
Fordparts.com is compiled by low paid interns FWIW and hardly the authority.
Josh
#149
#150
