6.2L V8 Discuss the 6.2L V8
Any Pics of 3" Lift w/35.12.5/20
Old 08-10-2013, 09:54 PM
Zooki1's Avatar
Zooki1
Zooki1 is offline
Would like to see any pics if you have a 3" lift w/35.12.5/20 wheels and tires. And has anybody had any issues/problems with this setup? Sorry...and I meant to say on a 2011
Old 08-11-2013, 11:02 AM
dualwheels66's Avatar
dualwheels66
dualwheels66 is offline
You don't need a lift for 35x12.5x20. Factory 20's are 34.2 in height and 11.5 wide, so it's really close. Also check out Toyo, BFG and Nitto's 295 width series.
Old 08-11-2013, 11:26 AM
Zooki1's Avatar
Zooki1
Zooki1 is offline
Sorry quess I should of gave a better desc. I currently have 275/70r/18 on a 2011 F250 4x4 crew cab and am thinking of going with 20x9 wheels with Nitto Terra Grapplers 295/60R20. And I thought a 3" lift would look good with this combination so I was curious if anyone had some pictures of this setup or close. Any photos or input would be appreciated..Thanks
Old 08-12-2013, 12:16 PM
ccstp's Avatar
ccstp
ccstp is offline
Lil bigger than what you were looking for. Hope it helps though. 4.5" lift. 37x13.5 Toyos
Old 08-12-2013, 12:58 PM
Amelio's Avatar
Amelio
Amelio is offline
I also plan on the same thing.....Ready lift has a 2.5" lift that goes right in for our gassers....there is one member that has it and its just the right amount of lift IMO
Old 08-12-2013, 02:50 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
3" may make it more susceptible to pointing to the sky with anything in the bed and/or a trailer hooked up to it.
I have a 2.5" readylift kit with 35s (on 18's though). Pics in the thread below:
https://www.ford-trucks.com/forums/1...ll-thread.html
Old 08-12-2013, 07:14 PM
Zooki1's Avatar
Zooki1
Zooki1 is offline
That is one nice looking trk, thanks for the pics....what brand of lift did you use?
Old 08-12-2013, 07:21 PM
Zooki1's Avatar
Zooki1
Zooki1 is offline
Matt,
That is a great looking trk also...I originally was looking for the grey but couldn't find what I was looking for. Just curious why you said the 3" might make it more susceptible to pointing to the sky?
Old 08-12-2013, 07:24 PM
Zooki1's Avatar
Zooki1
Zooki1 is offline
Amelio..do you remember who the member is? Is it Matt (silver bullet)
Old 08-13-2013, 03:09 AM
ccstp's Avatar
ccstp
ccstp is offline
Thanks bud! It's an ICON 4.5 stage 1
Old 08-13-2013, 05:56 AM
2000silverbullet
Matt,
Are you installing taller blocks in the back too? If not, raising the front that much might have it sit higher than the rear (especially if you have a 250 as they're almost level stock). Anything you put in the bed would have you sitting like a pre-runner truck (exaggerating, but you get my point).
Old 08-13-2013, 06:38 AM
Zooki1's Avatar
Zooki1
Zooki1 is offline
Ok now I get why you said that....I would do a 3" all the way around..yeh I agree with you, on if a person only put 3" in the front. Thanks for the input. Im new on here and I figured I would get more responses than I have
Old 08-13-2013, 08:41 AM
Amelio's Avatar
Amelio
Amelio is offline
I had to look in a previous conversation....the member is "RAPR" He actually did a 3.5" lift which is what is made for the 6.7.....I beleive he had to change his front drive shaft to make it work though.
I am not interested into getting into that much work....he suggested the ready lift 2.5" its a straight bolt in......I think it will give me just the right amount of lift for what I am looking for.....I then plan to get some pocket style flares and run some 35"s
Its a lil ways of cause the wife says I gotta wear my stock tires down first and seeing how I have only put 8600 miles on my truck since I bought it in December its gonna be a while
Old 08-13-2013, 05:34 PM
2000silverbullet
My wife said the same thing ("What's wrong with those tires?!?!" They'll never get it....), so I just aired up to Ford's recommended psi and had some fun skating around on them empty. They'll wear out quickly at that rate, trust me...
Old 08-13-2013, 07:24 PM
Worbly's Avatar
Worbly
Worbly is offline
Guest
Hopefully I can post up pics of my f250 with a 4.5" lift and 35x12.5x18R this weekend. She goes into the shop tomorrow to have a Carli pintop lift put on.
Quick Reply: Any Pics of 3" Lift w/35.12.5/20
