F600 Super Bronco build. Death Metal recommendations. Recipes.
#257
[QUOTE=78_f800crewcab4x4;16888640]
1973 metal "CUSTOM" glove box emblem added to match the theme, stencil taken from 1973 glove box to match mounting position exactly from right bottom corner
78_f800crewcab4x4, I have PM'd you about your radio delete plate. I would really appreciate it if you would reply. I've been looking for a long time for one that matches the color of my truck and will trade you another radio delete plate!
Thank you!
Thank you!
#259
on
Needed a cowl panel as the red f600 crew cab had damage to one side, incorrect antenna hole, different emblem holes and was not installed straight at the factory anyway. 1977 donor:
1977-1979 ford pickup cowl emblem holes are identical to 1978-1979 bronco:
1978 Bronco Custom emblem fits perfectly where it said f150 Ranger previously:
F-600 cowl to be replaced:
1972 ford pickup steering column-to-firewall mounting brackets are more beefy than 1977-1979. One is inner and one is outer. Will be using pickup steering column and not f600 column.
1972 ford pickup under-floor brace will be added under the crew cab floor to allow two more body mounts for strength. Floor pan shape is the same thru 1979, but only bumpsides and larger trucks retained the boxed brace that I acquired:
More metal!!!
Inquisition: Bloodshed Across the Empyrean Altar Beyond the Celestial Zenith
Helvetic Frost: misanthropic devotion
Archgoat: The Light-Devouring Darkness
Neurosis: Times Of Grace
Darkthrone: Arctic Thunder
Mortician: Hacked up for Barbecue
Bathory: Under the Sign of the Black Mark, Hammerheart
Goatwhor e: Blood For The Master
More metal!!!
#265
on
I can show some pics of what I did, and what I used.
There is a lot of galvanizing that needs to be stripped around the new weld sites before I can weld anything. Many of the drilled areas need to be repaired slightly. I need to align the panel better than the factory and test fit it with the windshield installed when I start welding. I need to also hammer out some bent areas at the antenna hole.
#267
on
Thanks Slik! Looks like a neat tool - I've seen them before, never used one yet.
That would be awesome.
Your work is very high quality so I'm interested to see the approach you take.
#268
#269
on
Blair spotweld cutters seem to work great. Several locations require just a ball-carbide burr to trim out the odd twisted spotweld.
Usually I drill the panel out I'm discarding and cut it up as I go to gain access.
Note how there are no holes in these two sections.
Some grunge:
Yob - Atma
Some rare hand picked black metal:
Batushka - Litourgiya
Some grunge:
Yob - Atma
#270
Love the work as usual.
I have all 3 of the tools pictured above. The blair "rotabroach" is by far the nicest/easiest.
The harbor freight spot weld cutters are just like the middle tool/blair spot weld cutter and do actually work ok for the price as well.
I've never tried using a carbide cutter for this but it totally makes sense that it would work with the oddball welds like you describe.
