Budd and Budd Type Tubless Wheels 22.5" 5 lug on 8" circle
#31
Category: Accessories
Price: $200
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Accord, CRX & pre '92 Civic
Item Condition: UT
Shipping Information: Item can be shipped
#32
Been a while, ive currently got a complete set of six 22.5" 5 lug tubeless wheels. They are $250 each in great shape. The nicest set I've had. Just sold my last complete set of 19.5"'s cleaning out the excess parts stash...
Nice 22.5. 5 lug wheels
Also have available 3. 6 lug 22.5" tubeless wheels if someone is in need. They are still attached to this 56 f600 dump truck but I could be convinced to remove them for someone.
#35
Hi Bob. I don't want to split up this set but I have a friend here on FTE "Stu" user name Truckdog. who has 2 he would sell. Ill have him stop by this thread.
I see that you have only one post here so sending recieving messsages or private messages probably wont work. If you want to call me 801-694-88two six I can give you his contact info.
Thanks
Thanks
#36
Thanks Josh. I do have two Budd 69930s that are 22.5" x 5.25" wide. Pictures below. I won't say that these are as nice as Josh has pictured but they are both straight and serviceable. The only mild scars I see are on the rear lip of the wheel with the tire still mounted. I'd value them at $200 each. If you don't want the old tire I'd ask you to cover the removal/recycling costs. I see that you live in Ohio, I'm in the Springfield, IL, area.
As Josh noted you don't have enough postings to do private messages. My email is stu_sandymcmillan at sbcglobal dot net. Stu
#38
They are not designed to accept the 9" tires, but they do work. Our friend Chuck Mantiglia of Chuck's Trucks was the first guy to tell me that he uses the 9R22.5s on his trucks with 5.25" rims. He said the tires crown a slight bit, but added that the crowning helps reduce steering input. He also said they don't have any issues with rear dual spacing.
Recently this same discussion was had with member Geno C who put them on his 1957 F-500. He posted pictures in his attached discussion thread. Stu
https://www.ford-trucks.com/forums/1...-5-wheels.html
