RSK with SD springs? 86 F250 + D60
Ok, I was going to run the D50 TTB for a while but a great deal on a 97 OBS F350 came up. So I'm going to swap in the D60 because I want a stick axle. Read all the pro's and con's of the D60 vs D50 and don't care - I want a stick axle.
So... Since I'm going to have the engine out and the front suspension stripped off anyway now... I'm thinking of a reverse shackle kit. I understand I'll have to box the front frame horns to use the kit on my 86 but that shouldn't be a big problem.
My question is about the SD front springs. I'm told I can move the RSK forward about 4" and use the later SD springs. Is it worth it in terms of ride quality? I was going to use the stock F350 springs most likely but if the lift/ride height wasn't what I wanted I would swap springs. Maybe I should just acquire a set of SD springs from the start?
Not sure this is the best place for this, if the mods feel it would be better in suspension please move it.
sjwalter71
05-29-2016 08:31 PM
ford4x4s
09-04-2011 03:23 PM
Barkin 40s
04-08-2011 05:25 PM
ozzy460
03-02-2008 07:45 PM
