paint code
Truck is pretty much flat faded black. No true color anywere I can't go by the dash because the truck was stolen one time in the past and I belive a completely different cab was installed. I'm pretty sure it was black but wanted to know if it ever had a 2 tone. Im in Allen park. Where you from?
Do you have the racetrack trim. Most 79's I have seen with racetrack trim were two tones. Maybe MikeoOoOo or numberdummy know a way to figure out your paint code without going thru Marti report but I sure don't. Are you trying to go back to the original color? I am in the process of a frame off on my 76 highboy. All pieces are epoxy primed. Am going to sand a lay a couple layers of 2k highbuild then block sand for final color. Can't make up my mind on color though. Stock was Hatteras Metallic Green but am leaning towards Highland Metallic Green.
The only sure way to tell what color it was from the factory is to send the VIN to Marti
Marti Auto Works - Concourse Quality, Hobbyist Price and request a "Marti Report". It will have a copy of the warranty plate and also tell you what color(s) the truck was originally.
You could also order a reproduction warranty plate so your cab's VIN would match the title. They also have the paper door cert too.
If you have the rating plate and the VIN matches the title and the frame then it is the correct tag for the truck. The paint code is on the rating plate.
Meridian_Mike
02-01-2019 03:19 PM
contento
11-29-2001 09:05 PM
