1949 Ford F1 226 Carb Gas Line Questions
So there is a problem with the carb, all good rebuilder said send it back and he is making right! Since the carb will be gone for a couple of weeks thought I would work on the next issue, CHANGING THE EXHAUST MANIFOLD.
QUESTIONS: the first bolt, the one nearest to the water pump is broken flush at the block. Plan is to try and extract it if not then tap it. What size (length and thickness) is this bolt. How deep does it travel into the block?? Since I may have to tap it I do not want to over drill the hole.
I wouldn't try to drill and EZ-out the broken stud. Best way is to lay a (plain steel, non-galvanized) washer over the hole with the broken off stud in it, and MIG the stud to the washer. Then MIG a nut onto the washer. The stud will almost always spin right out, the heat of welding frees it up, and you won't damage the threads in the hole.
Here's a video
Here's a video
B6A-9447-B =
SOEBY MOTOR CO. in Walhalla ND has 5 = 701-549-3711.
MILLER OBSOLETE PARTS in Binghamton NY has 6 = 607-722-5371.
GRIESEL MOTOR CO. in Okarche OK has 9 = 405-263-7242.
NOS PARTS LTD in Waxahachie TX has 15 = 972-937-2201.
See parts catalog pic at upper right in post 21.
1GA-9435-C .. Gasket-Intake to Exhaust Manifold / Obsolete
1948/51 226 I-6 Trucks & Ford Passenger Cars / 1950/53 254 I-6.
GREEN SALES CO. in Cincinnati OH has 14 = 800-543-4959.
Thanks for the Bolt Video!!
Awesome Ilya if I need it I will give you a call.
SO I was working on removing the manifolds this morning and ran into a jamm.
How the heck does one remove the the left and right nuts that are next to the center nut that holds the exhaust manifold. There is no room to work or get any of my tools or sockets in there.
For those that have removed these please please show me a pic of the tool that you used.
Thank You
Thank You
#28
