94 F 250 5.8 Gas Smell
Define "no codes" please. Ran key off scan and received no codes
When did the problem start? The smell which detected by better-half has been that way awhile
How long has it been since you replaced the plugs/wires/cap/rotor and filters? About 35,000 ago
Have you pulled the plugs to look for signs of unburned fuel/rich condition? No but will do tomorrow.
Thanks for the reply
The "10" is the separator code between the KOEO test and CM display. At least we know for sure now there are no apparent codes causing your issue. The KOER tests may reveal more.
I also highly suggest you check the Fuel Pressure Regulator for signs of a ruptured diaphragm. This will allow fuel to be drawn into the intake. Remove the vacuum line from the FPR, then cycle the key a few times. If you smell or see fuel coming out of the FPR, replace it. This is a very common problem.
Plugs that look gas fouled is another symptom of a leaking Fuel Pressure Regulator.
Bryan1532
11-15-2017 08:41 PM
NitrogenTSRH
10-16-2011 02:17 PM
