heater swap
The under-hood stuff is relatively easy, you'll need to remove the cowl to get at one bolt holding in the heater box, though.
For the stuff behind the dash, well, ya gotta drop the column & remove the dash, that takes a fair amount of time by itself - I'd give just that part 2-3 hours, depending on your tools & skill level.
Flex-head wrenches ROCK for this kind of work....
That's good.
I'm guessing you have A/C, then?
The scenario I had in my mind was an early 80s non-AC truck, replacing the heater core on such things is a PITA and, AFAIK, all 80-86 non-AC trucks are this way.
Here is a picture from the FoMoCo shop manual, the nut is being pointed to by the arrow near the M in FORD-TRUCKS.COM
TOPHER1978F150
18
10-07-2012 08:16 PM
Flat_Ford
11-05-2010 04:17 PM
Native Gearhead
10-27-2003 11:48 AM
