TheGageinator's Build thread with PICS!!
Wow, quite an accomplishment. Looks like your pretty talented and mechanically inclined.
Two questions - 1. When your camper is hooked up, does it sag in the back at all. I want to put a hitch on the back of mine, even though I won't be towing much, but when I stand in the bed, it seems like I'm bringing it down a bit. Maybe just an allusion.
2. I know this sounds dumb....but what is a throttle body and what does it do exactly? I know it somewhat does the job of a carb on a EFI engine, right? Where is it located at. I guess it would be good if I cleaned mine too.
Thanks for any help
-Cody
Thanks for any help
-Cody
The throttle body is located on the upper intake manifold. The intake tubes run into it. The throttle body controls the amount of air into the engine via the accelerator pedal. Is has those two blades that open and close to allow certain amounts of air through. If it is clogged up or really dirty it can cause performance issues as well as possibly having the plates of the throttle body stick open causing the truck to accelerate on its own. Not too likely but I image it can happen. Mine has 200k miles on and it is FILTHY, but I am too lazy to pull it again and clean it.
So is the throttle body hidden or can you access it fairly easy? Oh, and thanks for the response. I'm not mechanically inclined.
For a little more detail feel free to go through this:
1992 Ford F-150 Intake Removal for Injector Swap pictures, videos, and sounds | SuperMotors.net
The first few pics go over the throttle body area, then the rest are the full removal of the entire upper intake assembly. I STRONGLY suggest that if you plan to take the throttle body, upper plenum or anything off of the throttle body, that every gasket you come across you replace with new.
hey great post Evan P!! its nice to see other people helping the "less mechanically inclined" haha. and yeah it is pretty simple to remove the throttle body. just look at the pictures I posted and then look at your own engine bay. you can see what and where it is, and then see what needs to be done to get it off. there may be a plastic cover over your throttle body. I have mine removed in all the pics
Here's a good thread with lots of pics and it has a link containing donor cars also.
https://www.ford-trucks.com/forums/1...and-costs.html
here you go, you need to purchase (2) two fans
http://www.ebay.com/itm/BLUE-12-SLIM-FAN-MITSUBISHI-PUSH-PULL-ELECTRIC-RADIATOR-COOLING-12V-1730-CFM-/130792878474?hash=item1e73dcf18a&vxp=mtrwire the fans to PULL not push.
although these fans are cheap, they are awesome quality. I have used them on a few different vehicles. my single row radiator with these fans runs under half temp with ac on and pulling a 3k lb camper 200 miles. need any more proof? haha.
then from autozone, you need to get 2 mounting kits , a accessory relay, and a switch of your choice.(or wire to power with key, or electronics thermostat, whatever you want)
Just about any FWD Ford from the 90's. You also need a little different harness going to the alt, but it's not a big deal.
SWEET., youre the bomb. ill do this soon and post up pics and such
93-96 V8 Econoline with Air Conditioning or the High Output Alternator options
97-03 V6 Econoline E-Series or F-150
95-01 4.0 V6 Explorer or Ranger
94.5-97 Powerstroke Diesel F-Series
#28
3G alternator part numbers!
PART NUMBERS FOR THE SIDE MOUNT 3G ALTERNATOR ARE:
FORD NUMBER- F5UU-10300-AA768-7
CONFIGURATIONS AVAILABLE:
7768-7 (7 GROOVE PULLEY)
7768-8 (8 GROOVE PULLEY)
7768-6G1 (57MM OD PULLEY)
7768-6G2 (66MM OD PULLEY)
THIS ALTERNATOR REPLACES THE FOLLOWING PART NUMBERS: Ford F5UU-10300-AA
Last edited by TheGageinator; 07-04-2013 at 10:24 AM. Reason: 3G alternator part numbers!
