2005 Ford f250 2wd to 4wd conversion
Yes its possible only difference would be you would need the leaf sprung setup rather than the coils..
From what I've been reading, an '05-'07 4x4 front end will bolt right on to an '00-'04 truck. The holes match up for the 4x4 coil buckets and radius arms. The only real issue is the steering box. You need to get an '05-'07 box to fit the pitman arm, and just need longer bolts to mount it.
Hmm, I seem to remember somewhere that the brakes were the same. In which case, the best, least expensive route would probably be to find a donor truck with good axles and drivetrain. Did you do this conversion PSD? I know someone else on here has.
Yes I did a conversion on my 06.
Since some guys are running the f450/550 springs, wouldn't that mean that 05+ springs would fit in the buckets anyway?
Basically what I'm getting at is would it be easier to convert an 03 2wd to a 4x4 99-04 or a 4x4 05+ axle?
In theory, since the coil buckets are there, wouldn't I be able to skip the coil bucket step?
#28
In theory, since the coil buckets are uthere, wouldn't I be able to skip the coil bucket step?
#29
#30
The easy way is the floor shifted transfer case. Trying to run the ESOF setup would require a fair amount of wiring. I am not saying it wouldn't be possible, but it adds alot of extra work to the mix. You can re-use your electronic shift transfer case and remove the shift actuator. A bit of clever engineering and you can attached the manual shift linkage to the electronic transfer case. In reality though, you can sell your electronic t case and basically offset the price of buying the manual case.
