np435 shifter issue
np435 shifter issue
I have a problem with my np435 transmission, the problem is the shifter was removed while the trans was in gear I have read that you are supposed to remove the shifter when the trans is in neutral unfortuanatly it was not an option for me.Now I am wondering how hard it would be to reinstall the shifter, any help with this problem would be appreciated.
Do you ever get any responses. I am having the same issue. I removed the cover without thinking about what gear it was in. After inspecting the gears, flushing the housing and replacing the fluid now i am having troubles getting the cover back on and shifting properly. Anyone have any ideas???
In position like this, the three selectors will form a 'slot' that the shifter tip sits in.
The hardest part of the job is then pressing the retainer down against the spring pressure, to give it the necessary part-turn clockwise to lock it in position.
Eyeball (or measure) the fork spacings in neutral, then slide the collars into the same positions & try installing the lid without moving the collars out of position.
on
Remove the shifter from the tower. Look inside the hole. You will see two slots for the shifter to sit in.
Move the slots so they line up with one another. That is neutral. Use a screwdriver.
Look inside the transmission you will see corresponding rings the forks fit over. They are called synchros. Slide the synchros until they are equidistant between the corresponding gears. I will look around for some pictures to post.
