5R110 behind a 460? Is it doable??
Does anybody sell an adapter plate to put a 5R110 behind a 460? If not what are my options for automatic transmissions. I hear E4OD's suck and thats what I currently have. Would I be further ahead to just overhaul the E4OD with stronger parts?
I'm hoping to make at least 800ft-lb's torque with this thing some day. I want the transmission to be ready for it!
The E4OD was rated STOCK to be able to handle 1000ft/lb from what I have found out (kind of optimistic, but still...). The 5R110 is not a great mod, and that's why you never read of one of those in our trucks. Of course, everything can be done, but I advice against it. Do some research on some E4OD builds: for $3000 you can get a really bullet proof E4OD custom made for your exact needs. Right now if I were in your place I would run that stock trans while I build that engine up, then I would have the trans rebuilt and modified. As long as you don't become too crazy the stock trans will handle it. If it doesn't have one already, I advice adding an auxiliar ATF cooler.
Yeah adding a trans cooler, or a bigger/second one if it already has one is the plan for now. (From what I hear a deeper oil pan is a waste of money.) But a couple buddys of mine keep saying they hear all these horror stories of E4OD's going out. But I have found 1 online and everybody else says they are bulletproof. So I don't even know! The monster trans site says theirs are built for 800 ft-lbs which made me think the stock ratings were probably pretty low, but who knows. That monster kit sounds nice but for the money I would like to have something rated for 900-1000 to have a little overhead because I want to hit 800 and don't want to be right at the limit and have it go on me because I have a heavy right foot.
Gotta out pull them new diesels ya know!
Alright, I've already sent BTS an email, I will see if I can find that other guy.
Thanks for your help!
Right now I think my best bet will be buying a core E4OD and installing a Monster kit in it and swapping it out later. (Around $1300 for the kit and trans.) And throwing in a big transmission cooler.
jklapp86
04-01-2008 06:30 PM
superfsh
01-27-2005 07:23 AM
