1977 f100 300 6cyl 302 swap
This is a 1978 truck, the title is a typo
This is a short write up on how I changed and moved my motor mounts in my f100.. Swapping the old 300 out with a 302 is not the best way to go with an old 4x4 but the old 6cyl is tired and has low compression.. But because I have a perfect rear sump 302 and there us not a good write up I will be making it work and documenting it as I go!
Here is buckwheat
The original power plant that the previous owner ran for years with no breather!! Idiot
The removal
I went ahead and lifted the old goat
The 300 6 mounts are narrower and further forward than the correct
mounts.. just take the 6 bolts out and it pops right off
See the staggered bolts further toward the firewall? This is where the new 302 mounts go which are the same as the 351m mounts..
More to come!
Here is buckwheat
The removal
More to come!
That's true.. I'm on about 2 or 3 different forums with it and you would be amazed at how willing folks will help you for almost free if you're just nice to them
Here's the donor... I have personally finished 3 different projects with parts from this tired old monster..
We opted for the blue tipped wrench for this one
Heres the jewels
I6 left (on the left) beside v8 left (on the right)
I6 right (on the right) v8 right (on the left)
Got the v8, 302/351m on the right.. they bolt directly to the frame with NO MODIFICATION! All you have to do is dig the dirt out of the back hole
Here they are pretty as can be just before i tightened the right one down.. now she waits for a little American muscle..PS this will be getting a 351m before long
Heres the jewels
4 bolts let you swap to the correct bell housing.... The 351m is what I was raised around and it is a SWEET motor.. this will never be a mud bogg truck so all I need is "give or take" 150 horses to tote my big sexy (goofy) smile down the road
Well if you are comfy with it, ok, but your OP says 302. Of course, a stock 302 is a pooch as well, but like many (some, one?) here, I'm always happy to suggest how someone else should spend their time and money.
JUST so you don't have to suffer too much, consider a cam change and maybe a small 4bbl. Should give you 50 horse easy....serving suggestion, ymmv
