Duel Alt's not charging.
My 05 F350 turned over slow today and barley started. 12.4V with key off and 12.7 at idle with a good meter and 12.9 on the Bully Dog. This is after I found a lose wire on the top Alt. Cleaned and tightened main alt wire. If one Alt is bad is there a way to tell wich one? I will take the top one off tomorrow and get it checked. I watched the meter for a couple minutes and stayed very close to 12.7 after the glow plugs cycled. 12.71V + or - .05V
You SHOULD see 13.5+ after a start (many reports 14+) once the Glow plugs turn off. Could be you have bad batteries as well that won't hold/take a charge and that in turn can kill the alternator(s) - you should have everything tested individually (ie: REMOVED) otherwise you are just hoping. And you should always replace BOTH batteries at the same time - EVEN if only one is bad, since when the 'other' battery goes bad 'next time' it can weaken the other battery an you repeat this again.
Hopefully Lilpooh will be along to explain the operation of the dual alternators, but it seems strange that:
The PCM switches between the main alt, the aux alt or runs both alternators as needed.
So with hardly any running voltage something is whack as it seems unlikely for BOTH alternators to crap out at the same time.
I would almost look at a wiring or harness issue.
Josh
Josh
I pulled the batteries and both are maxing out my battery charger 1 at a time. I put it on 1 for a couple hours and its still at 15 amps. Last time I put new batteries in was 08. And yes both at once. I just got the truck back 2 weeks ago. I had Badger Diesel do the HPOP + all fittings and STC, also EGR delete + the Bully Dog and new EX. I will take both batteries in and get them load tested tomorrow. My meter will only do AC amps. I will borrow 1 from work that does DC Amps. If the batteries are good I will get both Alt checked. And yes I know it needs to be fixed before the FICM goes again. EDSFICM just redid mine a couple months ago. Thanks for any info.
Both batteries load tested good.
Both Alts. putting out close to 100 Amps when first started. First one then I can hear a click and it drops to zero then clamp on the other. After the glow plugs cycle it slowly goes down to 60 Amps + or - 5 Amps. On one Alt wire it shows -Amps and the other is ok with the meter on the same way.
Looking for wire or pin problems. Any ideas????
Should I pull the Alts and have them tested?
Jtpadilla1030
07-25-2018 08:19 AM
