2008 6.4 squeal on startup, even when hot
Listening to it today it does sound like this is the issue. Atleast I hope. Ill order up the parts tommorow and install when they arrive. Own beat bet or aftermarket? Also can I just replace the bearings in the idlers? I ushualy just go to Grainger and get some sealed bearings. 1/5 of the cost.
Just had my belts replaced a few months ago. Same issue. Squeaked on start up.
<a href="http://s68.photobucket.com/albums/i34/westwoodlands/?action=view¤t=11505A-8CB8-4AF0-94F7-8B0EFA8476AA-290-0000001DF038E645.mp4" target="_blank"><img src="http://i68.photobucket.com/albums/i34/westwoodlands/11505A-8CB8-4AF0-94F7-8B0EFA8476AA-290-0000001DF038E645.mp4" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
looked under truck this mornig and sure enough the outer tensioner was bad. no dealers open so I went to NAPA and got 2 new belts new tensioner. the idlers weren't in great shape so i'm replacing them as well. I cannot find a dia 17mm, outside Dia 48, with 14mm bearing anywhere. NSK- B17-102DG48. so i orderd 2 idler pulleys $25 each. At least I wont have to worry about it for a while. The inner tensioner seems fine, if it was in stock I would have picked it but no luck.
Not a very difficult job at all. second set of hands would probably help.
ceetwarrior
08-28-2019 10:36 AM
