What clutch for ZF5 swap
Truck is a 96 f150 4.9
ZF5 is from build date 5/22/91 its the S42
I like LUK clutches but I'll be damned theres a bout 6 different part numbers from LUk that all come up for my generic 92 f250 5.8 clutch
Can someone shine some light on this and what slave I use? I been searchin all week. If i had a powerstroke I'd find it in .5 seconds it seems
If there's nothing wrong with the clutch in the truck now, you can re-use it with the ZF. The slave cylinder may be the same between the ZF and Mazda transmission, but you would need to compare part numbers to be sure. You will need to use a '93-'96 slave cylinder because Ford changed the master cylinder bore diameter and the slave cylinder design to match somewhere around '93.
elliott000
12-28-2015 06:33 PM
Chris Braun
09-15-2012 06:37 AM
RawPower
13
05-06-2004 10:55 PM
Deividas93GT
10-30-2003 03:23 PM
