Can't turn key back after gets to point where electrical turns on
Alright, so I got this 1986 F250 XLT automatic transmission, gas fuel from our neighbors. Hasn't had a problem with getting the key out, except for maybe once but it came out my second try. So, when i turn the key forward, you get to the point where the electrical in the truck starts, and if you go any further the engine starts (There is probably a lot more complex things that go on that I don't know about, but i'm a novice at these types of things and don't know much about the names. I couldn't find out how to turn the brights off, since all I've ever drove before this was my parents newer cars that didn't have the floor button. But, i found out what that silver thing did on the floor, and how to set presets on the radio that day.)
So, once it gets to that point, the key will NOT turn back, and if the engine is started it won't stop the engine, if it is anything else other than reverse. Won't turn backwards in park, neutral, drive, second or first. Only reverse. So, to stop the engine, I have to put it into reverse, turn the key far enough for the engine to stop, then put it in park to get it the rest of the way out. I would also like to point out that it seems to idle at a fairly high RPM, but it has since the day we first started it.
So... Could anyone be able to enlighten me on why I can't turn the key backwards in anything other than reverse?
Thanks
Thanks
There are sort of 2 adjustments involved in the mechanism, and it is possible that yours is out on two at once. First, there is an adjustment between the lever's position and the transmission's position. It is a bolt/nut combo on the linkage below the column under the truck. I adjust them so the column is in Park when the tranny is in park - but set the park brake before adjusting it! Since the shift lever's position determines whether the key comes out or not regardless of what gear the tranny is in maybe that is the problem.
The second is with the pointer itself. Take off the black plastic collar around the column by removing one screw in it and you will see a screw holding the outside sheath of the wire that moves the pointer. Loosen the screw to get the pointer to indicate the proper position.
