Tempature gauge wont move
I have a 1990 f250 5.0 5speed 4x4 and the tempature gauge wont move. When you first turn the key on it goes from cold to a lil before colder but wont budge after that. I have done some thread searching and is there a possibility that there are to temp sending units. One for the gauge and one for the computer. I replaced the sending unit at the T-stat housing to no avail. Thanks Josh
Which temp sending unit did you replace? The 2 pin temp sending unit is for the ECU and the single pin sending unit is for the dash gauge.
A simple test to see if your gauge is bad, is short out the single wire sending unit's wire to the engine block, the temp gauge should peg out in hot.
If it does, then that sender is bad, if not, then the gauge or wiring to it could be the cause.
fordf348
04-24-2019 06:08 AM
Hakkamike
02-12-2014 01:03 PM
T. Sallinen
06-14-1999 04:10 PM
