1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Switching F-250 to Vinyl Floor
Old 06-22-2013, 05:27 PM
kmc0929's Avatar
kmc0929
kmc0929 is offline
2006 F-250 Crew Cab
Looking to take out the tan carpet and replace with the standard "work-truck" vinyl. Any major concerns with doing this? I assume it might be a little louder, maybe hotter?
I've taken the seats out before, would the carpet be difficult to remove? I assume if you go with the OEM vinyl you will have all the holes pre-drilled trimmed etc, aftermarket maybe not so much? Would love to do a brown or tan vinyl but I don't think it's offered from Ford.
Thoughts opinions?
Old 06-22-2013, 06:33 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
Did it in my truck and never looked back. Carpet is just laying in there. It will pull right out. I would reccomend a OEM floor. A lot easier of a install.
Old 06-22-2013, 06:35 PM
Mud Doc's Avatar
Mud Doc
Mud Doc is offline
Why not put Linex on the floor?
Old 06-22-2013, 07:55 PM
kmc0929's Avatar
kmc0929
kmc0929 is offline
So I assume you just take the seats out, take the console out and then take the door sills off?
My problems are the door pillars, no clue how they would come off, guess you need to remove seat belt? And in the rear the black plastic tray, the nut on the bottom spins free, I have no clue how to get it loose, have tried leveraging it with a screwdriver while turning it, nothing.
That said, would this defiantly be a DIY job or worth taking to an interior guy?
Unfortunately my truck has the center console, will that pose a problem as most of the XL trucks have a bench seat?
Line-X would be cool, but I am assuming there are wires and stuff down there that need to be covered? Has anyone tried?
Old 06-22-2013, 08:14 PM
fordman19762003's Avatar
fordman19762003
fordman19762003 is offline
IMO vinyl is the only way to go on a truck that will be used.I think the vinyl will deaden the sound a little better than Line X because unless things have changed the vinyl floors will still have a layer of insulation under it. I'll have to check my truck tomorrow to see if that's still the case since I have vinyl floors. You might get a little bit more heat transfer, but not enough that I would worry about it. I really don't think the job would be out of reach for the average guy who has an afternoon to spare, especially if you go with the OEM flooring.
Line X would be an awesome choice though too, since it's bonded to the floor you could just hose the cab out. That's something I wouldn't do with the vinyl flooring since water will find it's way underneath it. But my guess is that the Line X will be a lot more money since everything in the cab has to be ripped out and you're kinda stuck having the Line X shop do it since you really can't drive to them without and interior.
Old 06-22-2013, 10:55 PM
Firefighter 1406
It's totally a do it yourself job. I would give yourself a afternoon. The door pillars pull off toward the center. All you would need to do is get the bottom popped loose. Shouldn't have to take any seat belts off.
Old 06-23-2013, 09:01 AM
kmc0929's Avatar
kmc0929
kmc0929 is offline
So just grab the bottom of those pillar pieces and pull?
Any suggestions on that black plastic tray behind the back seat?
Was your vinyl OEM floor drilled for the console? Did you have to make any cuts or was it pretty much plug and play?
Old 06-23-2013, 09:42 AM
Firefighter 1406
I have to make a couple holes. Pull out your carpet and put it on top of the vinyl and cut anything you need before you put it in.
Old 06-25-2013, 01:39 PM
kmc0929's Avatar
kmc0929
kmc0929 is offline
Anyone have a checklist on removing the old carpet? Seat removal, consoles, and door sills are easy. I'm not sure about the rest., worried about breaking trim pieces, they can get expensive.
Old 06-25-2013, 05:28 PM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
I like that idea.
WhëëlMå1
2009 - 2014 F150
10-12-2017 10:17 AM
jtexfisher
39
11-18-2013 09:24 PM
whalebus2112
05-05-2012 06:34 PM
hkaiser83
Ford Truck Parts for Sale
04-12-2011 01:58 PM
jimmythesaint5897
15
07-15-2007 12:36 PM
Quick Reply: Switching F-250 to Vinyl Floor
