Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
08 Edge... No PS brake light or taillight
Old 06-23-2013, 02:27 PM
MotorPool's Avatar
MotorPool
MotorPool is offline
Hello all... I have a 2008 Ford Edge with 90xxx miles... vehicle came in with no passenger side turn signal... I replaced the bulb to no avail... I checked the wiring with a test light and now I have no brake light or turn signal. I have heard about possible melting/relay issues with these vehicles. Should I replace the fuse and the tail/stop light relay and go from there? The light socket appears to be slightly overheated but it does work. TIA
Old 06-26-2013, 10:25 PM
MotorPool's Avatar
MotorPool
Just an update on the problem. I switched the sockets and bulb from the passenger side to the drivers side and they work correctly so I know the socket isn't bad. We checked all the fuses and found a bad 15 amp fuse. We now have running lights but still no brake light or right turn signal. I checked the fuses/relays under the dash and the relays/fuses under the hood. Did I miss anything?
Old 06-30-2013, 08:53 PM
texan2004's Avatar
texan2004
texan2004 is offline
Did you verify the brake/turn signal worked when you switched them with the driver side? The only work I have done to this vehicle in the 65K miles we have owned it (since new) is to replace those bulbs. I have done the passenger side once and the driver side twice.
Chess67
03-19-2015 04:38 PM
jakegypsum
1999 to 2016 Super Duty
01-09-2014 02:47 PM
marine2651
12-16-2013 07:12 AM
RussF350
10-31-2011 06:22 AM
tommy929
02-23-2010 05:10 PM
Quick Reply: 08 Edge... No PS brake light or taillight
