How Low Can You Get It?
So, not real low, you're saying?
On a serious note, what about the A$$ end? It seems like a c-notched rear frame with a straight axle will not go low enough to make the truck sit at or near level to the front suspension as mentioned above. Am I wrong?
I thought my last '51 looked great when we used the drop spindles up front and reversed eye posies in the rear until I realized working under the truck was a major pita (it was even difficult to get a floor jack under it because there wasn't enough clearance to pump up the handle). Keep in mind that you may have to get under the vehicle at some point and unless you're built like Olive Oil (showing my age) you better think about being able to lift it somehow.
Wally
1951 F1 - ol' red
Wally
1951 F1 - ol' red
Thats my question - will that give the rear enough to sit as low as the front with dropped spindles, etc? I haven't seen one that looked low enough, they still have the rake to them. I looked at 1 that was low enough, but the air was out of the rear bags, and the axle was sitting inside the notch, so it would not drive like that. Driving would have to be raised up.
I have contemplated the T-bird IRS solely based on this, there is a poster on here tthat showed it on his F-1. I just though this would be a good place to bring this up.
Not for the faint of heart, Rokcrln has exceptional skills.
Thanks! That was the T-bird install I was referring to. The only concern I have is I should be between 650 and 700 hp. I'm a little nervous about the IRS with that. I've read that the Cobra parts interchange, and those make big power and seem to hold. I have not done lots of research on that yet. I have a Versailles 9" with 3.70 posi already that I would kind of like to use, which is why I ask about lowering the back.
I know my hp range is still little unrealistic to put to the ground without huge tires, etc. I have the motor and want it in the truck. I am willing to mini tub the bed into the frame rails, but I don't want the pro street steamroller look. I also do want to z the frame and raise the floor of the bed. I want it stay stock depth.
