After market performance shifter for 5 speed manual
I want to change my shifter since it is realy worn and tough to shift but don't want to just go with a stock replacement,I want to go with soemthing more performance oriented. Does anyone know have any ideas? if so please post links & more than one option would be great. The trans has 5 gears + reverse I looked in my chilton manual & there are 2 or 3 different 5 speeds: the mazda m5od, the ZF S5-42 & the ZF S5-47. I am not sure which one it is
Welcome to FTE.
Your profile says '96 F150, so that would be the Mazda box.
Just looking at Hurst and B&M, I do not see a shifter for that box.
That trans does have a history of wear in the shifter area, and shifter repair kits and shift forks are available and fairly easy to install.
Your truck may/should have an access panel in the floor, which will allow you to take the top off your trans.
The boxes used in T birds, Rangers & F150s are similar enough that these "how to" articles will help with your model also:
M5OD Mazda Design Manual Five Speed Transmission Preventative Measure .: Articles
In the first minute and 5 seconds, he takes the top cover off, and you can see the shift forks:
Repair kit. If you need forks, we can find those too:
M50D Ranger M5R1 F-150 M5R2 Shifter Repair Kit M50-SK
The F150 would have the Mazda "M5R2", as they call it.
As for a different stick, no idea. Got a welder????? You could cut it and make your own.
If you are in doubt--I really don't think you could get the ZF in an F150--take a look at it and compare here. Verical/horizontal ribs = Mazda, diagonal cross hatch ribs = ZF.
Ford F Series Truck P Series Van and Full Size Bronco Manual Transmission Rebuild Kits - Drivetrain.com
just-n-time
08-05-2008 09:49 AM
crackerloco
13
05-05-2007 12:52 PM
