DRW dana 80 abs ring gear on carrier?
Old 06-18-2013, 05:53 PM
mike9999's Avatar
mike9999
mike9999 is offline
I run 37" tires and I have had it with my 3.73 gearing and bad shift points. I have settled on 4.63 rear and 4.56 front. The issue is the carrier break in the dana 80 is 3.73-4.10. so I know I need a new higher ratio open carrier. My question is if I need a toner ring for ABS. if thats the case I have to buy one that can accept a toner ring.
The problem is 605926-1 is the BOM tag on the axle, when I search this dana does not say w/abs next to it. Page 74 http://www2.dana.com/pdf/X510-2.pdf
Top the housing has a wiring connector inline with where the toner ring would be. So I am pretty confident I need the ABS carrier anyway. your Thoughts?
Old 06-18-2013, 06:40 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
The F-450 trucks also have the D80 carrier ('99-'04). Available ratios are 4.88 and 4.30 and there may be some one out there who makes the 4.56.....I believe I saw it as being available once.
Point being...the F-450 unit would have the toner ring.
Old 06-18-2013, 09:22 PM
Nsaan's Avatar
Nsaan
Nsaan is offline
I believe the 450 carrier would be for the 450 axles also though...
Old 06-18-2013, 09:28 PM
Shake-N-Bake
Good point. That is the missing piece to the puzzle that I wonder about. I know the 350 DRW axle shafts are smaller than the 450 but I wonder if the splines are the same for the carrier? The photos I saw almost looked like the 350 axles taper up right at the ends where the splines are. I guess it would be interesting to find out if they are in fact different. When I had my axle shafts out of the 450, the shafts were pretty thick the entire length.
Old 06-19-2013, 12:12 PM
mike9999's Avatar
mike9999
mike9999 is offline
Sorry I forgot to mention its a f350 not 450
Old 06-19-2013, 01:01 PM
Shake-N-Bake
Donn, you are correct. The F-450 carrier accepts 37 spline axles where the F-350 carriers use a slightly smaller 35 spline axle. So, the F-450 parts won't be of any help to the OP.
trumsey07
11-18-2013 04:01 AM
cliffordingles
03-27-2011 03:41 AM
YoungFordAddict66
01-14-2009 10:34 AM
mustanginca
02-09-2008 06:33 AM
fordracer90
03-12-2003 09:47 PM
Quick Reply: DRW dana 80 abs ring gear on carrier?
