Recommendation for under bed gas tank
Old 06-21-2013, 01:55 PM
tacson's Avatar
tacson
tacson is offline
tacson has a great reputation on FTE.tacson has a great reputation on FTE.tacson has a great reputation on FTE.tacson has a great reputation on FTE.tacson has a great reputation on FTE.
Originally Posted by scf100 View Post
Did the 78 Bronco gas tank from Randyjacks thread
25.5 gallon tank and paid 123.00 from O'Reilly auto parts
Gas filler in drivers fender
looking good Stuart. I forgot do you have to move any crossmembers to get that Bronco tank installed? Also are those metal or glass rear fenders?
Old 06-21-2013, 05:14 PM
scf100's Avatar
scf100
scf100 is offline
scf100 is starting off with a positive reputation.
Here is an overhead shot of the 1978 Bronco tank.....25.5 gallon unit
Yes rear crossmember moved back....front one you see is the bed rail that has been slightly notched for clearance
Frame rail slightly notched for hose......metal tube slightly flattened to stay under wood bed
Old 06-21-2013, 05:19 PM
scf100's Avatar
scf100
scf100 is offline
View after bumper installed....brackets were lowered some to hide tank from view....small metal strip made to go between bumper brackets to fill gap and hide tank[IMG]
Old 06-21-2013, 06:06 PM
48 Steel's Avatar
48 Steel
48 Steel is offline
48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold48 Steel is a splendid one to behold
Originally Posted by 49willard View Post
Your roll pan would be directly behind the main cross bar for my class 4 trailer hitch. I think that I am seeing the cutouts in your roll pan. Have you run the exhaust to those openings. It does look a bit busy routing through the IRS!
Edit: Are you running outside the frame rails and around the coil springs in the rear perhaps?
Here are some pictures that should answer your questions Bill.
Old 06-21-2013, 06:37 PM
49willard
49willard is offline
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
Well done 48 Steel! If it was easy, anybody could do it.
Old 06-26-2013, 11:12 PM
Cen-cal56's Avatar
Cen-cal56
Cen-cal56 is offline
Cen-cal56 is starting off with a positive reputation.
I used a tank from a 86 Bronco II with o.e. skid plate. I checked out Randyjacks truck @ Western nationals a couple years ago and got fired up to relocate my tank. My filler will be in the left fender also.
Old 12-29-2014, 02:55 PM
Ibuildmyown's Avatar
Ibuildmyown
Ibuildmyown is offline
Ibuildmyown is a splendid one to beholdIbuildmyown is a splendid one to beholdIbuildmyown is a splendid one to beholdIbuildmyown is a splendid one to beholdIbuildmyown is a splendid one to beholdIbuildmyown is a splendid one to beholdIbuildmyown is a splendid one to behold
Fuel tank swap
Anyone thought of using a mid 80s chevy sububurban 40 gallon tank . frame rails are same distance apart. When I put the 7.3 diesel in my 53 F100 ,that's what I'm gonna use . Fuel door on rt rear fender.
Old 12-29-2014, 05:45 PM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
drptop70ss has a brilliant futuredrptop70ss has a brilliant futuredrptop70ss has a brilliant futuredrptop70ss has a brilliant futuredrptop70ss has a brilliant futuredrptop70ss has a brilliant futuredrptop70ss has a brilliant futuredrptop70ss has a brilliant futuredrptop70ss has a brilliant futuredrptop70ss has a brilliant futuredrptop70ss has a brilliant future
I would have to check dimensions but I would think the 40 gallon tank would take up too much room, maybe even getting in the way of the rear axle.
I am using 22 gallon 1995 chevy van tanks in my builds, factory setup for fuel injection with an in tank pump and will have the gas filler in the drivers side fender. I did not want my filler in the bed floor.
More pics are in both of my build threads.
Old 12-29-2014, 07:20 PM
smallello's Avatar
smallello
smallello is offline
smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.
I used the Mid-Fifty 22 Gal cross member mount with side fill in the driver side fender with a flip gas cap.
Old 12-31-2014, 09:25 AM
DougofMontana's Avatar
DougofMontana
DougofMontana is offline
DougofMontana is starting off with a positive reputation.
John, for some reason I can't view about six of the photos in the article on installing the mustang tank does anyone have this in a Word document, that they'd be willing to share?
Old 01-01-2015, 10:24 AM
Ibuildmyown
gas tank swap
When I use alternative parts I try to use common parts so as not to spend my hard earned money. Anyone can buy new and spend a fortune for the same results. A suburban fuel tank comes in three sizes and with or without a fuel pump in tank. The sizes are 25 gallon 28 3/4 x 28 1/8 x 10 3/4,31 gallon 28 3/4 x 28 1/8 x 12 3/4 , 40 gallon 35 x 28 3/4 x 13 1/8 . the neck fills from the right side . Those new parts look very nice though, thanks for the reply.
Old 01-01-2015, 12:14 PM
drptop70ss's Avatar
drptop70ss
True but when a brand new gas tank is less than $100 it doesnt make sense to work with 20 year old potentially leaking and rusted tanks.
  #28
Old 01-02-2015, 08:38 AM
jniolon's Avatar
jniolon
jniolon is offline
jniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant futurejniolon has a brilliant future
Doug, it should work now... I made some changes to the fonts and stuff got all wonky... it's the internet, go figure... let me know if it doesn't look right to you..
j
  #29
Old 01-02-2015, 09:57 AM
DougofMontana
John, thanks so much for going to the effort of repairing the document! I was afraid I was going to miss something important. I ordered my tank kit from CJPonyParts.com yesterday. I went with the 20 gallon kit that includes sending unit, and some mounting hardware. Of course the tank is on backorder, but the rest is on the way Thanks again for a great article!
David Fehir
1999 to 2016 Super Duty
03-30-2017 07:31 AM
Bparsch98
1997 - 2003 F150
03-28-2017 11:35 PM
Afullingim
05-16-2016 11:11 PM
hot-rod
30
01-13-2016 06:22 PM
rolldog1
11-18-2015 06:20 PM
Quick Reply: Recommendation for under bed gas tank
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
