Turbo Contamination Question (with picture)
Today I started the process of replacing my boots and installing the Riffraff Diesel plenum inserts.
As I disassembled everything, I noticed that there was contamination (?dust?) in what is the part of the turbo that connects to the manifold (I think you guys call it the spider). Please look at the picture and let me know if the contamination is indicative of a problem.
Thank you.
Thank you.
I've inspected my original turbo, the IC tubes, the inside of my intercooler, and my intake plenums (when I pulled them to install billet plenums). All my breathing hardware looks great, and I have never had to add oil between changes. I am confused as to why people modify the CCV... I am unsure what the goal is. I found nothing wrong with the way the system works, but my truck breathes deep and clean (Ford AIS).
With my experience, I would just get a better intake and sell the CCV mod.
The ccv in stock configuration:
Acts like a sand blaster on the compressor wheel.
Creates negative crank case pressure... thus masks potential blowby indications.
Leaves the cac tubes, compressor, spider all nasty with sludgey crud...
International designed the motor to have an open ccv....
I agree with Tugly. I've said it before and and ill say it again, I think the CCV mod is pointless. I've seen inter coolers with 300000 miles drained and the oil removed is measured in drops. Not that I don't advocate a nice flush everyone in a while.
Dave, I stopped by your house and left the air box clip. That should help seal the filter until your AIS shows up. I should have looked at your filter now that I think about it.
Also, your turbo does have an oring for the spider it's just stuck to the turbo. I'd suggest you leave it there. It's a pain to position when it's not held in.
Repair/replace the passenger side fuel line. Failure Prevention Thread
I upgraded my turbo and I saw what looks to be soot from the old exhaust leak more than anything else.
