tag decoding
Old Jun 16, 2013 | 12:21 PM
nineteen sixt5's Avatar
nineteen sixt5
tag decoding
Hi
I need help decoding a warranty tag. What year and month was this truck made.
F10JL665137
Thank you
Old Jun 16, 2013 | 01:24 PM
camperspecial65's Avatar
camperspecial65
its a 1965 F100 2WD 1/2 ton truck with a 240 6cyl engine built @ Michigan truck in March of 1965 as a 1965 model year truck.
- cs65
Old Jun 16, 2013 | 02:20 PM
nineteen sixt5
Thanks, the "J" in the tag threw me off because the info in the LMC cataloge indicates a 223 ci engine. But I thought the 223 was discontinued in 1965. Did the "J" change meaning in 1965.
Thanks
Old Jun 16, 2013 | 02:25 PM
camperspecial65
The decoder in the LMC catalog and most sources online are not right...the only accurate source is the Ford Master Parts Catalog which I and a few others on here have...Its an invaluable resource and can be purcghased for approx 21-22 dollars from hipoparts dot com.
- cs65
Old Jun 16, 2013 | 10:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
VIN engine code J: 1961/64 = 223 1V I-6 // VIN engine code J: 1965 = 240 1V I-6.
VIN engine code A replaced J in 1966 for 240, used thru 1974. 240 cancelled at the end of the 1974 model run.
Old Jun 17, 2013 | 06:52 AM
scottlathrop's Avatar
scottlathrop
replaced engine decode
[quote=NumberDummy;12529357]Block casting number should read: E0AE-6015- or 6059- followed by a letter suffix. There will be a date code on the block, decoding to the year/day the block was cast, similar to this: 0C7 = March (C) 7, 1980(0).
NumberDummy, I changed the starter today and got the numbers from underneath. They are from my 66 Flareside and the replaced engine.
The hidden numbers are EOAE D3C00 4B20.
I was told at the parts store' it appears to be a 302 from a 1980 bronco however you mentioned (without the numbers) it could be a Windsor. The Manifold is an Edlebrook so I'm still having trouble identifying the engine
Could you or someone confirm from this info what it actually is. Thanks in advance Bill,,
Scott
SAndrus00
Jan 5, 2019 12:59 AM
Giddy-Up96
Oct 17, 2014 07:50 PM
Airplaneit
15
Jul 12, 2012 03:03 AM
msquared100
Sep 27, 2010 02:49 PM
